I read about nemesis here, and I wanted to install it, but when trying to install the package with:
sudo apt-get install nemesis
I get this output:
Reading package lists... Done
Building dependency tree
E: Unable to locate package nemesis
So is this package no longer available then? Or is it just under a different name or something? If this package is no longer available on the main Ubuntu repositories, is there anywhere else from which I can get it? Or are there newer better packages which I should get instead of this one?
Update: My Universe repository is already enabled.
OS Information:
Description:    Ubuntu 14.10
Release:    14.10
Nemesis is not available in PPA now, you can still install it by following these steps :
Install dependencies
sudo apt-get install libdnet-dev libpcap-dev
Download nemesis-1.4.tar.gz-Click to download
Extract the archive and install
tar xzvf libnet-1.0.2a.tar.gz
./configure --with-libnet-includes=/usr/include/ --with-libnet-libraries=/usr/lib
make
make install
Here is nemesis
/usr/local/bin/nemesis
Click here for complete tutorial
Faizan Akram Dar
  • 4,569
  • 25
  • 31
The source is available here However, according to the change log this project hasn't been updated since 2004. Digging a bit deeper found this which appears was last updated 2013-04-11 but the code doesn't appear to have modified since May 2003 (based on filestamps in the archive). Perhaps an alternative would be useful.
Elder Geek
  • 36,752
