As Brasero dropped out of the core apps in 16.04, I tried to install brasero via APT but with no luck
sudo apt-get install brasero
The response tells me that there is no package brasero.
Brasero isn't found in the new Gnome Software either :-(
Do I need a specific PPA or this just because 16.04 is still beta?
EDIT:
For some reason the universe repository was not ticked in Applications & Updates. See answer below for the solution.
Zanna
  • 72,312
It's probably repository issue, Your /etc/apt/sources.list doesn't contain what is needed.
sudo echo "deb http://cz.archive.ubuntu.com/ubuntu xenial main universe" >> /etc/apt/sources.list
sudo apt-get update
For more informations You can check this article:
http://packages.ubuntu.com/xenial/brasero
Edit:
If you're using Ubuntu 18.04 LTS Live CD, you can check the Universe checkbox in "Software & Updates" (second one in screenshot) from the "show applications" menu. Universe Checkbox
Eska
  • 495
If you are facing similar problems after executing this command
Reading package lists... Error!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/in.archive.ubuntu.com_ubuntu_dists_xenial-backports_universe_binary-amd64_Packages
E: The package lists or status file could not be parsed or opened.
then please do
  1. sudo rm -vf /var/lib/apt/lists/*
  2. Now update list with sudo apt-get update
  3. Install brasero with sudo apt-get install brasero
Work for me Ubuntu 16.04
amc
  • 7,292
I used Synaptic's worked like a charm
system > Admin > Synaptic Package Manager
search brasero rightclick brasero mark for install
click apply Thats it
heli1
