I am trying to install Ubuntu 14.04 / 15.10 on my Dell XPS 13 9350 (November 2015).
I created a bootable USB disk which boots fine but the installer and the file manager do not detect the hard drive.
What is the problem? How can I solve it?
bcdedit /set {current} safeboot minimalSave & Exit.bcdedit /deletevalue {current} safeboot(Source)
So far the only workaround I found is to switch to AHCI Sata mode in BIOS settings:
Restart the computer and now the Ubuntu installer will detect the SSD.
Unfortunately this is not practical for a dual boot setup as Windows won't be able to boot in SATA mode so you every time will have to revert the BIOS settings when wanting to boot Windows.
The main problem is that DELL shipped with Windows pre-installed in IDE mode. The best solution in every aspect is to perform a clean installation of Windows. As a side effect you achieve one big advantage: pure Windows without any crap.
For those users who don't want to reinstall Windows, there is a way to switch to AHCI mode:
I had the same issue on an old HP Compaq & it was due to RAID format. I remove this in the BIOS menu:
