12
Is the Dell XPS 13 (9350) laptop compatible with the Ubuntu OS?
I'm new to Linux and Ubuntu but I'm minded to be a convert to open source software after disinterest in continuing to use Windows. I've been reading a lot of stories about problems with Linux failing to recognize the hard drive and the Wi-Fi has problems.
The laptop will come pre-installed with Windows 10 but I'm looking to erase that and install Ubuntu as my sole operating system. I'll try the Ubuntu demo first, but I'd like check on here as well.
9Cleggy2
  • 131
6 Answers6
Currently there are still some compatibility issues with the default Ubuntu installation.
Here is what you have to do to get a properly working Ubuntu system installation ...
Preparation
First of all - you won’t be able to connect to the internet out of the box from Ubuntu 15.10
because the WiFi card currently is not supported - for the installation you will need either :
  • An USB Wifi or Ethernet adapter dongle
  • an USB key containing the following kernel compiled by Cephyr (this kernel contains an additional patch for using this WiFi card).
Ubuntu will not detect your disk at once because the SATA-controller is set to RAID On.
Boot into BIOS (Press F12 at startup) and set the SATA-controller to Off or to AHCI.
Note : If you want to keep a dual boot with Windows, you have to follow this procedure.
Installation
Create a bootable USB/DVD Ubuntu 15.10 installation media.
Boot from it by selecting it in the BIOS menu. Install Ubuntu as usual.
Fixing issues
WiFi
When the installation is done, open a terminal (Ctrl+Alt+T) and install the patched kernel :
#Only if you have a USB WiFi/Ethernet adapter
wget http://secretundergroundla.ir/?ddownload=15
tar jxf xps13_9350_kernel.tar.bz2
sudo chown root:root brcmfmac4350-pcie.bin BCM-0a5c-6412.hcd
sudo mv -t /lib/firmware/brcm/ BCM-0a5c-6412.hcd brcmfmac4350-pcie.bin
sudo dpkg -i linux-headers-4.3.0-wifitest-custom_4.3.0-wifitest-custom-10.00.Custom_amd64.deb linux-image-4.3.0-wifitest-custom_4.3.0-wifitest-custom-10.00.Custom_amd64.deb
Reboot and WiFi should work properly now.
Update the system :
sudo apt-get update
sudo apt-get upgrade
Bluetooth
To make Bluetooth work properly you have to install the Broadcom firmware.
wget http://downloads.dell.com/FOLDER03272920M/1/9350_Network_Driver_XMJK7_WN32_12.0.1.720_A00.EXE
unzip 9350_Network_Driver_XMJK7_WN32_12.0.1.720_A00.EXE
cp Win64/BCM4350C5_003.006.007.0095.1703.hex ./
hex2hcd BCM4350C5_003.006.007.0095.1703.hex
mv BCM4350C5_003.006.007.0095.1703.hcd /lib/firmware/brcm/BCM-0a5c-6412.hcd
Reload the module and Bluetooth should work.
sudo modprobe -r btusb
sudo modprobe btusb
The Dell XPS 13 9350 is a good, but still quite new machine ... so please just give it some time,
everything will be fixed by Canonical and the community in the default Ubuntu installation ;-).
Sources :
Arch Linux Wiki,
XPS 13 (9350) WiFi with Ubuntu 15.10,
Install Ubuntu 15.10 on the Dell XPS 13 9343 (2015) : A complete guide.
hg8
  • 13,582
The following works:
First we upgrade the linux kernel to 4.4.
Download http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.4-rc7-wily/linux-image-4.4.0-040400rc7-generic_4.4.0-040400rc7.201512272230_amd64.deb and then:
$ sudo dpkg -i linux-image-4.4.0-040400rc7-generic_4.4.0-040400rc7.201512272230_amd64.deb
$ sudo apt-get update
$ sudo apt-get upgrade
Next install some updated firmware tools:
$ sudo apt-get install firmware-b43-installer
And then download and install the following firmware: http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.154_all.deb and
$ sudo dpkg -i linux-firmware_1.154_all.deb
Restart your machine, and you should have wifi!
I cannot comment sorry for making an answer. For Ubuntu 14.04 with Dell xps 13 9350 I installed kernel 4.4-rc6 which made wifi, bluetooth, suspend and audio work.
I made instructions based on all the instructions I found on the internet here: https://github.com/awesomebytes/ubuntu14_dell_xps13_9350
Kernel 4.4 has been released and should fix most of the issues now. (I have it installed and not experienced any issues so far.
If your XPS 13 (like mine) is equipped with a NVMe SSD you'll have to compile a custom kernel where you enable the nvme module. Otherwise the kernel won't be able to find the SSD.
To do so, do the following: First get the necessary packages
$ sudo apt-get install git fakeroot build-essential ncurses-dev xz-utils
$ sudo apt-get install kernel-package
$ sudo apt-get install libssl-dev
Get kernel 4.4.
$ wget https://cdn.kernel.org/pub/linux/kernel/v4.x/linux-4.4.tar.xz
Unpack it
$ tar xvf linux-4.4.tar.xz
$ cd linux-4.4/
Copy your current config file
$ cp /boot/config-$(uname -r) .config
Now edit the .config file with your favorite editor to enable the NVMe module.
nano .config
Search for CONFIG_BLK_DEV_NVME and set it to y (from m)
CONFIG_BLK_DEV_NVME=y
Now it's time to compile your custom kernel. (the last command can easily take up to 1.5 hours)
make-kpkg clean
fakeroot make-kpkg --initrd --revision=1.0.NAS kernel_image kernel_headers
And install! (ignore the warnings coming from the first one)
$ cd ..
$ sudo dpkg -i linux-headers-4.4.0_1.0.NAS_amd64.deb
$ sudo dpkg -i linux-image-4.4.0_1.0.NAS_amd64.deb
Now just reboot and it should start in kernel 4.4.
Additionally after a few reboots I ran into problem where my screen would remain black. Seems like thereś an issue with skylake and graphical drivers.
For me it was fixed by making a change to the grub file.
sudo nano /etc/default/grub
Then change the line saying GRUB_CMDLINE_LINUX_DEFAULT to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i915.preliminary_hw_support=1"
Save and apply the changes using:
sudo update-grub
Source for making custom kernel: http://www.cyberciti.biz/faq/debian-ubuntu-building-installing-a-custom-linux-kernel/
EDIT: Turns out after a few reboots my black screen is after boot is back.. so this is more of a work in progress.
As of this week, the newly released 4.4 mainline kernel is compatible with xps 9350 a few small simple additional configurations.
  1. create a new directory to hold all the bits we'll download
    mkdir v4.4-wily
    cd v4.4-wily
  2. download the latest kernel from ubuntu mainline (I used only the generic)
    wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.4-wily/linux-headers-4.4.0-040400-generic_4.4.0-040400.201601101930_amd64.deb
    wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.4-wily/linux-headers-4.4.0-040400_4.4.0-040400.201601101930_all.deb
    wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.4-wily/linux-image-4.4.0-040400-generic_4.4.0-040400.201601101930_amd64.deb
  3. Install that
    sudo dpkg -i *.deb
  4. get the firmware for the latest intel i915 drivers
    wget https://01.org/sites/default/files/downloads/intelr-graphics-linux/sklgucver43.tar.bz2
    tar xf sklgucver43.tar.bz2
    cd skl_guc_ver4_3/
  5. edit to make sure the properties are correct (use the defaults unless you know what you are doing)
    vim install.sh
    sudo sh install.sh
  6. if you have an NVME SSD, the latest boot images don't load the nvme module by default so you may get the dreaded, unresolvable
    ALERT! /dev/disk/by-uuid/##### does not exist.
    which drops the bootload down into busybox. The solution is to load the nvme kernel module for the boot image:
    sudo vim /etc/initramfs-tools/modules
    add
    i915
    nvme
    as the last lines (I added the i915 module for giggles)
  7. rebuild the boot images
    sudo update-initramfs -u
    sudo update-grub
  8. follow step by @yancysmith
    install the latest firmware deb
    sudo dpkg -i linux-firmware_####_all.deb
  9. follow the steps from the arch linux wiki to install the Bluetooth firmware
  10. reboot and rejoice!
Note: you can follow many previous articles to make the machine dual boot windows 10 and Ubuntu nicely without reinstalling windows.
Ray
  • 101
I did most of what was mentioned above except adjusting grub, which got me closer to my wifi working but not completely. I was able to use my phone as a hotspot through bluetooth to grab Internet in the meantime.
I then stumbled on this post http://blog.friimaind.it/03/01/2016/installare-ubuntu-15-10-gnome-su-dell-xps-13-9350/ (it's in Italian) and it mentioned this file: /etc/modprobe.d/blacklist.conf. Please sudo gedit /etc/modprobe.d/blacklist.conf or vi if you choose and check which modules are blacklisted.
Whatever you do, please check this file to see what kernel modules are blacklisted. PLEASE DO THIS!
It turns out that the bcmwl-kernel-source driver was blacklisted in favor of firmware-b43-installer and b43fwcutter. Jumping into synaptic, uninstalling the bcmwl-kernel-source driver, and installing both 'firmware-b43-installer' and 'b43fwcutter' as well as rebooting is what worked for me.
Take note, this is after I updated my firmware to the latest one dell has of 2/2/2016, which you can find here: wget http://downloads.dell.com/FOLDER03502638M/1/XPS_9350_1.2.3.exe then you want to copy: sudo cp XPS_9350_1.2.3.exe /boot/efi. You then jump into your bios at start (F2 for me) scroll down to bios flash update and do what you gotta do.
Then I upgraded to 4.4 and the rest of it except the grub stuff. I don't mess with grub unless there is no other way. I also upgraded from Gnome 3.16 to 3.18 since I was using my phone as wifi, which killed the refusing to shutdown bug although that has again raised its lovely head.
Good luck.
Andre
  • 19
