230
Many sysv init scripts used a corresponding file in /etc/default to allow the administrator to configure it. Upstart jobs can be modified using .override files. How do I override or configure systemd units, now that systemd is the default in Ubuntu?
muru
  • 207,228
systemd units need not obey files in /etc/default. systemd is easily configurable, but requires that you know the syntax of systemd unit files.
Packages ship unit files typically in /lib/systemd/system/. These are not to be edited. Instead, systemd allows you to override these files by creating appropriate files in /etc/systemd/system/.
For a given service foo, the package would provide /lib/systemd/system/foo.service. You can check its status using systemctl status foo, or view its logs using journalctl -u foo. To override something in the definition of foo, do:
sudo systemctl edit foo
This creates a directory in /etc/systemd/system named after the unit, and an override.conf file in that directory (/etc/systemd/system/foo.service.d/override.conf). You can add or override settings using this file (or other .conf files in /etc/systemd/system/foo.service.d/). This is also applicable to non-service units - you could do systemctl edit foo.mount, systemctl edit foo.timer, etc. It assumes .service as the default type if you didn't specify one.
Overriding command arguments
Take the getty service for example. Say I want to have TTY2 autologin to my user (this is not advisable, but just an example). TTY2 is run by the getty@tty2 service (tty2 being an instance of the template /lib/systemd/system/getty@.service). To do this, I have to modify the getty@tty2 service.
$ systemctl cat getty@tty2
# /lib/systemd/system/getty@.service
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
[Unit] Description=Getty on %I Documentation=man:agetty(8) man:systemd-getty-generator(8) Documentation=http://0pointer.de/blog/projects/serial-console.html After=systemd-user-sessions.service plymouth-quit-wait.service After=rc-local.service
If additional gettys are spawned during boot then we should make
sure that this is synchronized before getty.target, even though
getty.target didn't actually pull it in.
Before=getty.target IgnoreOnIsolate=yes
On systems without virtual consoles, don't start any getty. Note
that serial gettys are covered by serial-getty@.service, not this
unit.
ConditionPathExists=/dev/tty0
[Service]
the VT is cleared by TTYVTDisallocate
ExecStart=-/sbin/agetty --noclear %I $TERM Type=idle Restart=always RestartSec=0 UtmpIdentifier=%I TTYPath=/dev/%I TTYReset=yes TTYVHangup=yes TTYVTDisallocate=yes KillMode=process IgnoreSIGPIPE=no SendSIGHUP=yes
Unset locale for the console getty since the console has problems
displaying some internationalized messages.
Environment=LANG= LANGUAGE= LC_CTYPE= LC_NUMERIC= LC_TIME= LC_COLLATE= LC_MONETARY= LC_MESSAGES= LC_PAPER= LC_NAME= LC_ADDRESS= LC_TELEPHONE= LC_MEASUREMENT= LC_IDENTIFICATION=
[Install] WantedBy=getty.target DefaultInstance=tty1
In particular, I have to change the ExecStart line, which currently is:
$ systemctl cat getty@tty2 | grep Exec
To override this, do:
sudo systemctl edit getty@tty2
And add:
[Service]
ExecStart=
ExecStart=-/sbin/agetty -a muru --noclear %I $TERM
Note that:
  1. I had to explicitly clear ExecStart before setting it again, as it is an additive setting, similar to other lists like Environment (as a whole, not per-variable) and EnvironmentFile; and unlike overriding settings like RestartSec or Type. If I did not clear it, systemd will execute every ExecStart line, but you can only have multiple ExecStart entries for Type=oneshot services.
    • Dependency settings like Before, After, Wants, etc. are also lists, but cannot be cleared using this way. You'll have to override/replace the entire service for that (see below).
  2. I had to use the proper section header. In the original file, ExecStart is in the [Service] section, so my override has to put ExecStart in the [Service] section as well. Often, having a look at the actual service file using systemctl cat will tell you what you need to override and which section it is in.
Usually, if you edit a systemd unit file, for it to take effect, you need to run:
sudo systemctl daemon-reload
However, systemctl edit automatically does this for you.
Now:
ExecStart=
$ systemctl show getty@tty2 | grep ExecS ExecStart={ path=/sbin/agetty ; argv[]=/sbin/agetty -a muru --noclear %I $TERM ; ... }
And if I do:
sudo systemctl restart getty@tty2
and press CtrlAltF2, presto! I'll be logged into my account on that TTY.
As I said before, getty@tty2 is an instance of a template. So, what if I wanted to override all instances of that template? That can be done by editing the template itself (removing the instance identifier - in this case tty2):
Overriding the environment
A common use case of /etc/default files is setting environment variables. Usually, /etc/default is a shell script, so you could use shell language constructs in it. With systemd, however, this is not the case. You can specify environment variables in two ways:
Via a file
Say you have set the environment variables in a file:
$ cat /path/to/some/file
FOO=bar
Then, you can add to the override:
[Service]
EnvironmentFile=/path/to/some/file
In particular, if your /etc/default/foo contains only assignments and no shell syntax, you could use it as the EnvironmentFile.
Via Environment entries
The above could also be accomplished using the following override:
[Service]
Environment=FOO=bar
However, this can get tricky with multiple variables, spaces, etc. Have a look at one of my other answers for an example of such an instance.
Variations in editing
Replacing the existing unit entirely
If you want to make massive changes to the existing unit, such that you're effectively replacing it altogether, you could just do:
systemctl edit --full foo
Temporary edits
In the systemd file hierarchy, /etc takes precedence over /run, which in turn takes precedence over /lib. Everything said so far also applies to using /run/systemd/system instead of /etc/systemd/system. Typically /run is a transient filesystem whose contents are lost on reboot, so if you want to override a unit only until reboot, you can do:
systemctl edit --runtime foo
However, you cannot use this method to temporarily override something that is already in /etc (e.g., snap service files are usually created directly in /etc/systemd/system, so you can only override them using files in /etc/system/system/<snap-service-name>.service.d).
Overriding user units
Everything said so far also applies to user units, with systemctl --user edit, systemctl --user daemon-reload, etc. instead of the corresponding system unit commands. The override files go to ~/.config/systemd/user instead of /etc/systemd/system. If, as an administrator, you want to override user units for all users, then use /etc/systemd/user instead.
Setting specific properties
Many resource-control properties can be set directly using the systemctl set-property command. Example from the manpage:
systemctl set-property foobar.service CPUWeight=200 MemoryMax=2G IPAccounting=yes
Changes are applied immediately and also persisted to override files. For example, the following command will immediately update the service's resource configuration:
systemctl --user set-property foobar.service CPUWeight=200 MemoryMax=2G
And also add the following files in the user's home directory (because --user makes it a user unit):
% head .config/systemd/user.control/cann.service.d/50-*
==> .config/systemd/user.control/cann.service.d/50-CPUWeight.conf <==
# This is a drop-in unit file extension, created via "systemctl set-property"
# or an equivalent operation. Do not edit.
[Service]
CPUWeight=200
==> .config/systemd/user.control/cann.service.d/50-MemoryMax.conf <==
[Service] MemoryMax=2147483648
Undoing changes
You can simply remove the corresponding override file, and do systemctl daemon-reload to have systemd read the updated unit definition.
You can also revert all changes (including ones from systemctl set-property):
systemctl revert foo
Further Reading
Via this mechanism, it becomes very easy to override systemd units, as well as to undo such changes (by simply removing the override file). These are not the only settings which can be modified.
The following links would be useful:
muru
  • 207,228
