I could use help with adapting the standard courier-authdaemon initscript.
I run a small business server with postfix, courier, mariadb, amavisd-new with clamav and spamassassin and sasl. After the upgrade to xenial I had problems because the setup refused to authenticate sasl as before. I learnt googling around that this was the result of a seriously broken libpam-mysql in xenial. Fortunately it is possible to authenticate against couriers authentication routines in courier-authdaemon, so I changed my postfix smtpd.conf to point to that. The courier-authdaemon is controlled by an initscript (in /et/init.d) as follows:
#! /bin/sh -e
### BEGIN INIT INFO
# Provides: courier-authdaemon
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
### END INIT INFO
prefix="/usr"
exec_prefix=${prefix}
sysconfdir="/etc/courier"
sbindir="${exec_prefix}/sbin"
daemonscript="${sbindir}/authdaemond"
rundir_courier="/var/run/courier"
rundir="/var/run/courier/authdaemon"
pidfile="${rundir}/pid"
. /lib/lsb/init-functions
# Check for a leftover init script
if [ ! -x $daemonscript ]; then
exit 0
fi
case "$1" in
start)
# Start daemon.
cd /
log_daemon_msg "Starting Courier authentication services" "authdaemond"
if [ ! -d "$rundir_courier" ]; then
mkdir -m 0775 $rundir_courier
chown daemon:daemon $rundir_courier
# set file context for SELinux (#668564)
[ -x /sbin/restorecon ] && /sbin/restorecon $rundir_courier
fi
if [ ! -d "$rundir" ]; then
mkdir -m 0750 $rundir
fi
$daemonscript start
log_end_msg 0
stop)
# Stop daemon.
cd /
log_daemon_msg "Stopping Courier authentication services" "authdaemond"
$daemonscript stop
log_end_msg 0
restart|force-reload)
$0 stop
$0 start
status)
status_of_proc -p "$pidfile" "" "authdaemond" && exit 0 || exit $?
echo "Usage: $0 {start|stop|restart|force-reload|status}" >&2
exit 2
esac
exit 0
Next issue: I have postfix running in a chroot jail, which cannot access the standard courier-authdaemon socket. So I found this:
service courier-authdaemon stop
rm -rf /var/run/courier/authdaemon/ /var/spool/postfix/var/run/courier/authdaemon/
mkdir -p /var/spool/postfix/var/run/courier/authdaemon/
ln -s /var/spool/postfix/var/run/courier/authdaemon/ /var/run/courier/authdaemon
service courier-authdaemon start
postfix reload
Which basically stops the authentication daemon, removes the old stuff in both the current directory and the one in the postfix chroot jail and then sets them up again and sets the link from outside to inside the chroot jail and starts everything back up again. Which works. What it doesn't do, is make these changes permanent, because after a reboot (or an update/upgrade of courier) courier sets everything up anew, so I have to redo the above fix.
So obviously I was trying to find out whether someone would have found something to apply the fix at bootup. Turns out there was somebody, and he rewrote the authdaemon initscript as follows
! /bin/sh -e
### BEGIN INIT INFO
### END INIT INFO
prefix="/usr"
exit 0
fi
#== Postfix chrooted ==#+20131117 <GB@Nline.it>
postfix_check() {
local PFINIT=/etc/init.d/postfix
local PFMASTER=/etc/postfix/master.cf
local PFSMTPD=/etc/postfix/sasl/smtpd.conf
if [ -s $PFINIT ] && [ -s $PFMASTER ] ; then
# Use Postfix
if [ "$(/usr/bin/awk '$1~/^smtp$/ && $8~/smtpd/ {print $5}
' $PFMASTER)0" != "n0" ]
then # chroot: Yes
if [ -s $PFSMTPD ] && [ "0$(/bin/sed -n \
-e '/^authdaemond_path:/s,.\+:\s*,,p' $PFSMTPD)" = "0$rundir/socket" ] &&
[ ! -L $rundir ]
then
/bin/rm -fr $rundir &&
/bin/ln -s /var/spool/postfix/$rundir $rundir_courier
fi
else # chroot: No
if [ -L $rundir ] ;then
/bin/rm -fr $rundir
fi
fi # Postfix chrooted ?
fi # Use Postfix
} # postfix_check()
#-- Postfix chrooted --#
case "$1" in
start)
# Start daemon.
cd /
fi
postfix_check
fi
$daemonscript start
log_end_msg 0
stop)
# Stop daemon.
cd /
$daemonscript stop
log_end_msg 0
$0 stop
$0 start
status)
exit 2
esac
exit 0
The problem is: it doesn't seem to work, and my skills at regular expressions are not such that I can debug this. I have a suspicion it has to do with file locations, but I'm not sure. Is there anyone who can point me in the right direction so I don't have to remember to apply the commands after a reboot?
