10
I am running ubuntu 16.04 and since few days it takes around 5 min to boot up. I looked related questions but I could not find how to troubleshoot my problem. When I run:
systemd-analyze blame
I get this utput:
5min 2.242s networking.service
     21.128s vboxdrv.service
      5.637s NetworkManager-wait-online.service
      3.436s apt-daily.service
       592ms dev-sda1.device
       462ms lightdm.service
       442ms plymouth-quit-wait.service
       389ms libvirt-guests.service
So I guess networking.service is causing the problem. Can somebody help me to fix that? thank you
dufte
  • 14,198
  • 41
  • 43
diegus
  • 487
Maybe it is a workaround but I could reduce the boot up time following the answer at https://ubuntuforums.org/showthread.php?t=2323253, i.e. by editing the file:
sudo vim /etc/systemd/system/network-online.targets.wants/networking.service
And changing the following line at the end of the file:
TimeoutStartSec=5min
to:
TimeoutStartSec=30sec
I have then rebooted the system and it works fine.
If you dont want to reboot the system again, just reboot the daemon by:
sudo systemctl daemon-reload
diegus
  • 487
The answer by diegus is risky, because the file /etc/systemd/system/network-online.targets.wants/networking.service is a symlink to /lib/systemd/system/networking.service. This is owned by the ifupdown package and should not be modified: changes will be overwritten on the next upgrade of this package.
Better is to create a systemd override file:
/etc/systemd/system/networking.service.d/override.conf
[Service]
The easiest way to create this file is through systemctl itself:
$ sudo systemctl edit networking.service
This will automatically also reload the file. Use systemctl cat networking.service to see if it worked.
Thomas
  • 438
The solutions above did not help me as my USB WLAN adapter stopped working after that.
But setting sudo nano /etc/network/interfaces under Ubuntu 18.04
#from
auto lo br0
iface lo inet loopback
# to
auto lo
allow-hotplug br0
helped, as suggested here: https://askubuntu.com/a/1061852/650800
The slow startup occurred after following this tutorial to install KVM.
hb0
  • 251
