I have an nfsroot created from 14.04 that I am rebuilding using 16.04. My nfsroot is shared by three systems named pc1,pc2 and pc3. There are 3 matching user accounts named pc1, pc2, and pc3 as well.
When these systems boot up they automatically log in and subsequently run a bash login script.
In 14.04 I replaced mingetty in my upstart tty1.conf file as follows:
# tty1 - getty
# This service maintains a getty on tty1 from the point the system is
# started until it is shut down again.
start on stopped rc RUNLEVEL=[2345] and (
not-container or
container CONTAINER=lxc or
container CONTAINER=lxc-libvirt)
stop on runlevel [!2345]
respawn
#exec /sbin/getty -8 38400 tty1
script
exec /sbin/mingetty --autologin `cat /proc/sys/kernel/hostname` --noclear tty1
end script
This worked just fine in 14.04 for my purposes. It gleans the hostname from /proc and then uses that as the login name.
What I am trying to do is replicate the same behaviour in 16.04, but now using systemd.To do so I modified /etc/systemd/system/getty.target.wants. Specifically I changed the ExecStart:
ExecStart=-/sbin/agetty -a $HOSTNAME --noclear %I $TERM
However from reading the systemd docs and using some google-fu I have leared that I cannot use backticks or environment variable substitution in the ExecStart line. I have tested hard coding a user account instead and it works correctly, but I can't figure out how to do the same thing I was doing previously with upstart in systemd.
I've also tried using a small script for this purpose as well by changing the ExecStart line to:
ExecStart=/bin/sh -c "/usr/bin/autogetty.sh"
The autogetty.sh script is simple script which cats to get the hostname and feeds it to mingetty. It however doesn't appear to work. I think the issue may be that for the service, the type is idle and from my researching online it needs to be fork. I have yet to try modifying the service type yet.
I would like to know the "right way" to do this. So far I'm just trying things to make it work, and even if I make it work I won't be sure if its the best way of doing it.
Thanks.
