I use a VPN (PIA installed by this method) on Ubuntu 16.04 through the default Network Manager. Frequently--after around 5 minutes of streaming or ~1 hour of normal browsing--it is cutting out, by which I mean everything fails, including direct connections to a given IP.
After digging through /var/log/syslog, I found this sequence of events, which seems to be the culprit:
Apr 8 17:41:43 ***** nm-openvpn[9107]: [83d27bda14f33782df085b09962c2dfa] Inactivity timeout (--ping-restart), restarting
Apr 8 17:41:43 ***** nm-openvpn[9107]: SIGUSR1[soft,ping-restart] received, process restarting
Apr 8 17:41:45 ***** nm-openvpn[9107]: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Apr 8 17:41:45 ***** nm-openvpn[9107]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 8 17:41:45 ***** nm-openvpn[9107]: RESOLVE: Cannot resolve host address: us-east.privateinternetaccess.com: Temporary failure in name resolution
Apr 8 17:42:20 ***** nm-openvpn[9107]: message repeated 8 times: [ RESOLVE: Cannot resolve host address: us-east.privateinternetaccess.com: Temporary failure in name resolution]
Sometimes it is preceded by this:
Apr 8 10:47:28 ***** nm-openvpn[4716]: TLS Error: Unroutable control packet received from [AF_INET]*.*.*.*:**** (si=3 op=P_CONTROL_V1)
Apr 8 10:47:56 ***** nm-openvpn[4716]: message repeated 3 times: [ TLS Error: Unroutable control packet received from [AF_INET]*.*.*.*:**** (si=3 op=P_CONTROL_V1)]
However, everything I found about this indicates a time synchronization issue, which I don't have.
Here's the openvpn process spawned by Network Manager:
/usr/sbin/openvpn --remote us-newyorkcity.privateinternetaccess.com 1194 udp --comp-lzo --nobind --dev tun --auth-nocache --reneg-sec 0 --syslog nm-openvpn --script-security 2 --up /usr/lib/NetworkManager/nm-openvpn-service-openvpn-helper --bus-name org.freedesktop.NetworkManager.openvpn.Connection_8 --tun -- --up-restart --persist-key --persist-tun --management /var/run/NetworkManager/nm-openvpn-b0ce41de-070b-42c7-af39-90961791ebeb unix --management-client-user root --management-client-group root --management-query-passwords --auth-retry interact --route-noexec --ifconfig-noexec --client --auth-user-pass --ca /etc/openvpn/ca.crt --user nm-openvpn --group nm-openvpn --chroot /var/lib/openvpn/chroot
(I can't find where in NM to change any of these options...)
Any idea where the problem may be?
