I am trying out MAAS but I am having trouble getting the node to reach the internet. This is my setup:
3 physical machine, with 1 of them having two network cards acting as gateway, cluster controllers and region controller. The gateway/controller is setup to have one interface receive IP from the corporate network and while having the other managed by MAAS (both DHCP and DNS.)
From the gateway, I have no problem reaching out, but the Nodes cannot. I looked at the controller/gateway, I can see that bind9 is running.
$ service bind9 status
* bind9 is running
Doing dig ubuntu.com give me results. But if I do dig @127.0.0.1 ubuntu.com, I get no return. I also look through the bind config and everything seems to be in order (forwarder is setup.) What am I missing?
Here are the relevant bind configs
$ cat /etc/bind/named.conf
include "/etc/bind/named.conf.options";
include "/etc/bind/named.conf.local";
include "/etc/bind/named.conf.default-zones";
$ cat /etc/bind/named.conf.options
options { directory "/var/cache/bind";
dnssec-validation auto;
include "/etc/bind/maas/named.conf.options.inside.maas";
auth-nxdomain no;
listen-on-v6 { any; }; };
$ cat /etc/bind/maas/named.conf.options.inside.maas
forwarders {
172.24.3.136;
