How can I pass a command-line argument to the atd daemon which will persist across reboots and package upgrades? I wish to add the command line flag -l 7.5 to atd because I have an 8-CPU server and don't want to wait for the load level to go below the compiled-in value of 1.5 before running batch jobs.
(A similar question has been answered here, but that answer is not valid for Ubuntu 16.04 because the file /etc/init.d/atd.conf does not exist, and there is no line "exec atd" in my /etc/init.d/atd file.)
Unlike most of the scripts in /etc/init.d/, there is no corresponding atd file in /etc/defaults/ so I can't make any edits in there.
Here is the /etc/init.d/atd script:
#! /bin/sh
### BEGIN INIT INFO
# Provides:          atd
# Required-Start:    $syslog $time $remote_fs
# Required-Stop:     $syslog $time $remote_fs
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Deferred execution scheduler
# Description:       Debian init script for the atd deferred executions
#                    scheduler
### END INIT INFO
# Author:       Ryan Murray <rmurray@debian.org>
PATH=/bin:/usr/bin:/sbin:/usr/sbin
DAEMON=/usr/sbin/atd
PIDFILE=/var/run/atd.pid
test -x $DAEMON || exit 0
. /lib/lsb/init-functions
case "$1" in
  start)
        log_daemon_msg "Starting deferred execution scheduler" "atd"
        start_daemon -p $PIDFILE $DAEMON
        log_end_msg $?
  stop)
        log_daemon_msg "Stopping deferred execution scheduler" "atd"
        killproc -p $PIDFILE $DAEMON
        log_end_msg $?
  force-reload|restart)
    $0 stop
    $0 start
  status)
    status_of_proc -p $PIDFILE $DAEMON atd && exit 0 || exit $?
    echo "Usage: /etc/init.d/atd {start|stop|restart|force-reload|status}"
    exit 1
esac
exit 0
I have tried adding -l 7.5 to the end of the start_daemon line in the start) section but that didn't make any difference (I still have a job in my queue although my load level is below 7.5; and ps -ef | grep atd | grep -v grep yields daemon 23192 1 0 07:57 ? 00:00:00 /usr/sbin/atd -f)
derHugo
  • 3,376
  • 34
  • 52
nickcrabtree
  • 1,213
What you're looking at there is an old-style SysV init file. Although systemd provides a mechanism (for backward compatibility) to start services via such files via a sysv init compatibility mode, Ubuntu 16.04 does not appear to do so in this case, so your changes to the init file are simply ignored - I'm not sure why the file is still present.
Instead, the atd service is started directly by systemd, using the unit file /lib/systemd/system/atd.service. However, rather than editing that file directly, you should use systemctl edit to create a custom configuration as described in @muru's excellent answer How do I override or configure systemd services?
Specifically,
sudo systemctl edit atd
then add for example
[Service]
ExecStart=
ExecStart=/usr/sbin/atd -l 7.5 -f
Save and quit, then restart the service unit
sudo systemctl restart atd.service
After that you can confirm your change has taken effect using
systemctl status atd.service
You should see something like
● atd.service - Deferred execution scheduler
   Loaded: loaded (/lib/systemd/system/atd.service; enabled; vendor preset: enab
  Drop-In: /etc/systemd/system/atd.service.d
           └─override.conf
   Active: active (running) since Sat 2017-06-10 09:38:30 EDT; 8min ago
     Docs: man:atd(8)
 Main PID: 17247 (atd)
   CGroup: /system.slice/atd.service
           └─17247 /usr/sbin/atd -l 7.5 -f
Jun 10 09:38:30 xenial-vm systemd[1]: Started Deferred execution scheduler.
steeldriver
  • 142,475
