91
I am writing this because I am very confused about installing PostgreSQL 9.3 on my Ubuntu 14.04. First I need it for my Python/Django development, and I ran into the problem when I tried to install it. Now I have this error and it is driving me crazy:
postgresql-9.3 : Depends: postgresql-client-9.3 but it is not going to be installed
                 Depends: postgresql-common (>= 142~) but it is not going to be installed
I have found some solutions online (How do I resolve unmet dependencies after adding a PPA?), and I did everything to the Preventive Measures part, because I have had some broken packages problem, and again after I had this error show to me again.
The second thing I have followed the official PostgreSQL installing tutorial (http://www.postgresql.org/download/linux/ubuntu/), and I have had duplicated repositories, but I have deleted them and I have added a fresh one but still this error.
copser
  • 1,396
  • 14
  • 22
6 Answers6
74
You can install the package using.
make sure the repo sources are up to date
sudo apt-get update
To Install the package.
sudo apt-get install packagename
Once the package determines that you have some missing dependencies, run the following command to fix broken or missing dependencies.
sudo apt-get install -f
Above command will only download the missing dependencies if you have already installed the package.
Tim
  • 33,500
67
I know I'm a bit late, but none of the above solutions worked for me. What really solved my problem was to use aptitude instead of apt-get. aptitude will suggest resolutions to the problem.
Simply run these:
sudo apt-get install aptitude
sudo aptitude install <package-name>
aptitude will suggest dependencies resolution for you e.g:
The following actions will resolve these dependencies:
Keep the following packages at their current version:
  1. libyaml-dev [Not Installed]
Accept this solution? [Y/n/q/? (n)
Downgrade the following packages:
  1. libyaml-0-2 [0.1.4-3ubuntu3.1 (now) -&gt; 0.1.4-3ubuntu3 (trusty)]
Accept this solution? [Y/n/q/?] (Y)
as discussed in this post.
15
Sometimes the dependencies that need fixing are unrelated to the program you are trying to install. In my case it was giving off this error:
The following have unmet dependecies
shashlik : Depends: libc6-i386 but it is not going to be installed
Depends: lib32gcc1 but it is not going to be installed
Depends: lib32z1 but it is not going to be installed
It turned out that I had tried to install a program called "Shashlik" and the installation had failed. So I ran the code:
sudo apt-get --purge remove shashlik
And then I ran:
sudo apt install autoconf
This seemed to fix the error as my program then installed. I am not sure how much the second command helped but I put it there in case it was necessary for the solution to work.
Let me share with other people my experience with installing postgresql-9.3. First of all I have been struggling with this for about 4/5 days, and I finally manage to do it.
All went wrong with these nasty errors I have shared in my first post, as I have tried to google it and discover that people have more less the same error, or struggling to solve a similar one.
Long story short, you have a very nice answer here how to resolve unmet packages:
My mistake was that I have made duplicated repository, and the answer in this link solved that, this command sudo apt-get install -f just made another error, you must do this manually, at least I did it (read to the section Preventive Measures, but you could read to the end, it is an imba post).
Second I manage to google this post from official PostgreSQL page http://www.postgresql.org/message-id/20140327084212.GA12703@msgid.df7cb.de (this is the error people usually have when they are struggling with installation of postgresql), this led me to
https://wiki.postgresql.org/wiki/Apt, this is the proper way for adding PostgreSQL Packages to your system, just read it and do it step by step.
Third step are series of commands provided in the @vembutech post:
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install postgresql-9.3 postgresql-contrib-9.3
copser
  • 1,396
  • 14
  • 22
First of all you've to find the package that is broken. Let's say you're getting following error,
 libpython3.9 : Depends: libpython3.9-stdlib (= 3.9.5-3~20.04.1) but 3.9.4-1+bionic1 is to be installed
You've to manually remove the files of broken package.
To get the list of the files you can run
sudo ls –l /var/lib/dpkg/info | grep -i libpython3.9-dev
Replace libpython3.9-dev with your own package name.
Output
libpython3.9-dev:amd64.list
libpython3.9-dev:amd64.md5sums
Now, you can to discard these files.
sudo rm /var/lib/dpkg/info/python3.9-dev*
Perform the same operations for the rest of packages.
Once it's done, you can run
sudo apt --fix-broken install
This time the above command should work fine.
Bal Krishna Jha
  • 368
  • 14
Try by installing the with below command.
sudo apt-get install postgresql-common=151.pgdg12.4+1
Tim
  • 33,500
BDRSuite
  • 3,196
  • 13
