So it started here:
wine *.exe
it looks like wine32 is missing, you should install it.
as root, please execute "apt-get install wine32"
I try then:
sudo apt install wine32
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: shim-signed : Depends: grub-efi-amd64-signed but it is not going to be installed or grub-efi-arm64-signed but it is not installable Depends: grub2-common (>= 2.04-1ubuntu24) E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I have recently upgraded system twice: from Ubuntu 18.04 to 20.04 and from 20.04 to 22.04(.1) Popular solution to purge grub doesn't work - it gives the same "shim-signed" error. Also update, upgrade, autoremove, install -f gives nothing. Grub repair and re-installation also doesn't solve.
Oh, and I'm not using (U)EFI boot, just legacy BIOS, no efi partition at all. What can I possibly try before complete OS re-installation - to get wine working again?
tricky
  • 41
