Ubuntu 16.04.6 LTS and trying to install ffmpeg.
$ sudo apt install ffmpeg
Reading package lists... Done
Building dependency tree
ffmpeg is already the newest version (7:4.1.3-0york1~16.04).
You might want to run 'apt-get -f install' to correct these:
 cuda-libraries-dev-10-1 : Depends: libcublas-dev (>= 10.2.1.243) but it is not going to be installed
 cuda-samples-10-1 : Depends: libcublas-dev (>= 10.2.1.243) but it is not going to be installed
 cuda-visual-tools-10-1 : Depends: libcublas-dev (>= 10.2.1.243) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
It says ffmpeg is already the newest version, which it is not (V1.4 is the most current one afaik). I tried checking ffmpeg version:
$ ffmpeg -version
The program 'ffmpeg' is currently not installed. You can install it by typing:
Note: I looked over other posts and added this apt repo:
sudo add-apt-repository ppa:jonathonf/ffmpeg-4
I was able to install ffmpeg using pip3 and that installed to
/usr/local/lib/python3.5/dist-packages/ffmpeg.
Can anyone help with this problem?
