I was trying to setup a backup server with Ubuntu 18.04 Server
user@host:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.1 LTS
Release:    18.04
Codename:   bionic
but I ran into a dependency error even thou the dependencies that fail are installed.
user@host:~$ sudo apt-get install  amanda-server amanda-common  xinetd gawk gnuplot readline-common
Reading package lists... Done
Building dependency tree
readline-common is already the newest version (7.0-3).
gawk is already the newest version (1:4.1.4+dfsg-1build1).
 amanda-common : Depends: adduser but it is not going to be installed
             Depends: debconf (>= 0.5) but it is not going to be installed or
                      debconf-2.0
             Depends: update-inetd but it is not going to be installed
             Depends: perl (>= 5.22.1-3) but it is not going to be installed
             Depends: perlapi-5.22.1
             Depends: libcurl3 (>= 7.16.2) but it is not going to be installed
 amanda-server : Depends: libcurl3 (>= 7.16.2) but it is not going to be installed
 cron : Depends: adduser but it is not going to be installed
        Depends: libpam-runtime (>= 1.0.1-11) but it is not going to be installed
 gnuplot : Depends: gnuplot5-qt but it is not going to be installed or
                gnuplot5-x11 but it is not going to be installed or
                gnuplot5-nox
 init-system-helpers : Depends: perl-base (>= 5.20.1-3) but it is not going to be installed
 libgd3 : Depends: libfontconfig1 (>= 2.11.94) but it is not going to be installed
 libpam0g : Depends: debconf (>= 0.5) but it is not going to be installed or
                 debconf-2.0
 libssl1.0.0 : Depends: debconf (>= 0.5) but it is not going to be installed or
                    debconf-2.0
 nginx-common : Depends: debconf (>= 0.5) but it is not going to be installed or
                     debconf-2.0
 python3 : PreDepends: python3-minimal (= 3.6.5-3ubuntu1) but it is not going to be installed
       Depends: python3.6 (>= 3.6.5-2~) but it is not going to be installed
       Depends: libpython3-stdlib (= 3.6.5-3ubuntu1) but it is not going to be installed
 python3-service-identity : Depends: python3-openssl but it is not going to be installed
 wireless-crda : Depends: crda (>= 1.1.1-1ubuntu2)
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I did notice missing packages: update-inetd, perlapi, gnuplot5-qt. But I'm not sure if installing them will fix the missing dependency error on the installed packages too.
How can I install it on Ubuntu Server 18.04?
Melebius
  • 11,750
