In order to learn Linux I built a small Linux machine. A week ago I installed posrgresql and pgadmin3. All worked fine. Today it seems that pgadmin3 has disappeared. I tried to "find it back" with sudo find / -name pgadmin3* -print. whereis pgadmin3 returns /usr/share/pgadmin3. There is a /usr/share/pgadmin3 directory but it contains no executable pgadmin3, it contains other files though.
I tried a reinstall and got the message:
$ sudo apt-get install pgadmin3
Reading package lists... Done
Building dependency tree
pgadmin3 : Depends: libwxbase3.0-0 (>= 3.0.0) but it is not installable
Depends: libwxgtk3.0-0 (>= 3.0.0) but it is not installable
I did the following to recover as per this article:
sudo apt-get install -f
apt next suggested to remove the dependencies and I did so, but the error persists. My questions:
- is it possible to recover pgadmin3?
- if not, how can I overcome this frustrating install error?
- something I can hardly expect an answer for, but what have I done to create this mess?
Postgres (9.5) still works and with psql I can query the database. I use Mint/Mate 18.1. Postgres and pgadmin3 were installed from repository: deb http://apt.postgresql.org/pub/repos/apt/ trusty-pgdg main.
All suggestions are very welcome. Thanks very much in advance.
