-2
Could you please let me know what it the correct method to remove Anydesk?
I am receiving this error, while I am trying below command:
sudo apt-get remove anydesk
The following packages have unmet dependencies: linux-tools-5.15.0-56 : Depends: linux-tools-common but it is not going to be installed E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
#additional#
sudo apt-get autoclean
sudo apt-get autoremove
Try this below comments
sudo apt autoremove anydesk --purge -y
To remove Repositories;
sudo rm /etc/apt/sources.list.d/anydesk.list
sudo rm /usr/share/keyrings/anydesk.gpg
Once the package is broken we need to use this command to fix it. sudo apt --fix-broken install
