I tried to install some programs but i got the following errors:
Selecting previously unselected package op-jre:i386.
(Reading database ... 281698 files and directories currently installed.)
Preparing to unpack op-jre_1.5.0-14_i386.deb ...
Unpacking op-jre:i386 (1.5.0-14) ...
dpkg: dependency problems prevent configuration of op-jre:i386:
op-jre:i386 depends on libxp6.
dpkg: error processing package op-jre:i386 (--install):
dependency problems - leaving unconfigured
op-jre:i386
. cleaning up temporary files
Installation complete.
The program isn't working and when i try
zeena@S:~/Desktop$ sudo apt-get check
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
op-jre:i386 : Depends: libxp6:i386 but it is not installable
E: Unmet dependencies. Try using -f.
I already tried sudo apt-get autoremove, update and upgrade but that won't help. Any ideas what else i can try?
