I've installed the current nvidia restricted driver and rebooted my machine and now I get a black or blank screen.
How can I fix this?
How can I fix this?
Log in to a terminal: Ctrl+Alt+F1 (terminal is visible with a blank screen)
sudo apt-get remove --purge nvidia-*
sudo apt-get remove --purge xserver-xorg-video-nouveau xserver-xorg-video-nvsudo apt-get install nvidia-commonsudo apt-get install xserver-xorg-video-nouveausudo apt-get install --reinstall libgl1-mesa-glx libgl1-mesa-dri xserver-xorg-coresudo dpkg-reconfigure xserver-xorgSource: Ubuntu Wiki
Remove any drivers that may be causing the issue,
open the terminal and type ( open it from the dash, using the ubuntu icon on the left corner)
sudo apt-get --purge remove nvidia
or
sudo apt-get --purge remove nvidia-current
(Depending on which one you have installed) or deactivate them from the restricted driver settings.
reboot.
then on a terminal type this:
sudo apt-add-repository ppa:ubuntu-x-swat/updates
sudo apt-get update
sudo apt-get install nvidia-current nvidia-settings
reboot.
In my case it was a problem with the monitor giving my Nvidia GPU a bad EDID
To debug your error, you can add this line to the screen section in the the /etc/X11/xorg.conf file
Option "ModeDebug" "true"
Now check your /var/log/Xorg.0.log file.
If you find an error like this:
NVIDIA(0): Unable to get display device DFP-0's EDID; cannot compute DPI
Then you can resolve it by adding this line to the device section
Option "IgnoreEDIDChecksum" "DFP"
Maybe Ubuntu IT'S working but using another card output. For me, my nVidia GeForce 7300 has 2 output, a VGA and a DVI. It seems like the default output when you install the drivers is to DVI but I don't have a DVI monitor so I managed to get to Recovery Mode (available in GRUB when you boot) and type this:
nvidia-xconfig --twinview --twinview-orientation="Clone"
Now Reboot.
This command directs the same graphics to both outputs. From there on, you can keep experimenting with this nVidia utility until you get what you want. For more information type:
nvidia-xconfig -A | less
Hope that helps.
Press Alt+Ctrl+F1 to get to tty1 (terminal), then run this:
sudo apt-get --purge remove nvidia*
That will remove any nvidia driver packages. If that still doesn't work, try this also:
sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.mybak
That will remove a corrupted xorg configuration file if it exists. You will need to reboot after finishing these commands. (Ctrl+Alt+del)
PS. If you have an nvidia optimus card, do not install the x-swat or any other nvidia drivers. The best working drivers for nvidia optimus cards come from the bumblebee project.
This happened to me when running an AMD cpu: Learned it was an IOMMU/AMD -v Bug = Incompatible with Nvidia. Disabling Virtualization bios settings fixed this.
Does that thread on Ubuntu Forums help you?
In short, it seems that the linux-header packages for some of the kernels (notably the PAE kernels) are not properly installed, and the nvidia driver compilation fails silently when installing the nvidia packages.
I was getting a black screen when booting. I have a NVIDIA 6200 graphics card. Renaming xorg.config and rebooting worked for me. The xorg.config file created by nvidia-xconfig: version 304.51 (buildmeister@swio-display-x86-rhel47-06.nvidia.com) was causing the problem.
The biggest trouble I had was getting a Macbook Pro to install the Nvidia drivers!!!
The solution is to change the Master Boot Partition to REMOVE EFI and go with Legacy MBP.
This is discussed on a few webpages but is not so easy to follow.
https://bbs.archlinux.org/viewtopic.php?id=162289
Using this idea, I booted from a Live CD and then using Gparted removed the EFI boot partition, changed it from EFI to FAT32 and then using Boot-Repair rebuilt it as a legacy boot using the main Partition with 13.04 64 bit installed
https://help.ubuntu.com/community/Boot-Repair
---WARNING BACK UP YOUR DATA FIRST. YOU COULD SCREW UP EVERYTHING ON YOUR HDD ---
Insert Live CD - Boot up as try Ubuntu Run Gparted - Change EFI boot partition from EFI to FAT32.
open a new Terminal, then type:
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
Press Enter.
Then type:
sudo apt-get install -y boot-repair && (boot-repair &)
In boot repair select ADVANCED OPTIONS
Uncheck Use the Standard EFI File under main options Uncheck Separate /boot/efi partition under GRUB LOCATION
follow prompts on how to use the legacy Boot loader that Boot Repair will give you.
Now install and load the NVidia drivers as many post
I used the method 2 on this page http://www.dedoimedo.com/computers/ubuntu-ringtail-nvidia.html
I was working on this for probably 18 hours and tried EVERY option available. I mean every possibly way to install these friggin drivers, and this was the only solution that works for the Macbook Pro 7.1 Running 13.04 with Nvidia_current (nvidia_304)
Regarding the topic title: What is the current restricted nvidia driver version used in Ubuntu natty?
You can find anything about releases, versions, bugs, requested features on Launchpad. To understand what it is about you can take their tour.
The question about the latest version of the nVidia driver can be found on “nvidia-current” binary package in Ubuntu Natty i386. So as of 2011-04-20 the latest version is 270.41.06-0ubuntu1. But that is not necessarily the recommended one. The latest one for me always seems buggy (like 'tearing' etc).
Instead of using nvidia-current you should really try to use an older nvidia driver e.g. the 173.xx. This solved the problem for me. Just start jockey-gtk and chose the 173.xx driver. Than reboot your system.
Try in /etc/default/grub:
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
#GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
#GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
GRUB_GFXMODE=1680x1050x32
Replace "1680x1050x32| with your native resolution (to get it run vbeinfo in the grub console when booting).
Then in /etc/grub.d/00_header:
set gfxmode=${GRUB_GFXMODE} <-- FIND THIS LINE
set gfxpayload=keep <-- ADD THIS LINE DIRECTLY BENEATH
Update grub:
sudo update-grub
Might work...
Try acpi=off. That solved my booting into blank screen issue for Ubuntu 11.10.
I've tried everything here and the solution for me was to switch to lightdm, works perfectly now!
I got a blank screen as well, but this was on a laptop with and nVidia optimus card 4200m. Optimus does not seem to be supported well on Ubuntu. I had to disable optimus from the bios and then reinstall the nividia driver. More here if you want to read http://developerslog.org/?p=69
