I'm running Ubuntu 14.04 LTS and updated my graphics card to Nvidia Quadro K4200 in order to get stereo capability. It worked with the recommended Ubuntu driver (nvidia-352), although I struggled to get stereo working, so I installed the latest Nvidia driver (361.42). To do this, I got a terminal with
Alt-Ctrl-F1
stopped X with
sudo service lightdm stop
and then ran the install script from NVIDIA. When I restarted X with
sudo service lightdm start
I got a black screen with a blinking cursor in the top left of the screen and Alt-Ctrl-F[1-6] did not give a terminal login. My only option is a hard shutdown (holding down the start button) and when I reboot it returns to the black screen.
I saw this post which looks the closest to my problem that I found, with a solution that requires Alt-Ctrl-F1 which isn't giving me a terminal login option. Any suggestions are very much appreciated.
Two thoughts: For low level logins, like you're doing, frequently the ENTER key must be pressed to get a login prompt.
Just because the graphics are crazy, doesn't mean that the daemons like sshd didn't come up properly.
I had a very similar problem with NVIDIA install script. I've booted into recovery mode (hold SHIFT before loading GRUB for a menu) and there was an option to open a root terminal.
Try those commands, reboot and see if it will fix your case:
dpkg-reconfigure xserver-xorg
update-initramfs -u
You might need to remount with write priviledges to make those changes:
mount -o remount,rw /
With terminal you can of course remove NVIDIA and re-install nouveau-firmware, just run that update-initramfs -u afterwards. I think I fixed it just like that, but it was some time ago and my memory is foggy...
GreggD
  • 1,164
  • 19
I noticed on desperate rebooting I intermittently got a login prompt, sometimes giving my a couple of minutes of access before returning to the black screen and flashing cursor. I found in /var/log/kern.log the following error:
NVRM: API mismatch: the client has the version 361.42, but
NVRM: this kernel module has the version 352.63. Please
NVRM: make sure that this kernel module and all NVIDIA driver
NVRM: components have the same version
NVRM: nvidia_frontend_ioctl: minor 255, module->ioctl fauled, error -22
I ran
dpkg --get-selections | grep nvidia
for a list of nvidia packages that might be causing the conflict and removed and purged all of them individually
apt-get remove *package*
apt-get purge *package*
I also re-ran the NVIDIA driver install script to generate a customised kernel setup for good measure and re-ran the install.
This got me to the login screen on reboot, although logging in kept returning me to the login screen, but I could at least ctrl-alt-F1 for a terminal and there was plenty of help on this issue already on Ask.
-1
Have you checked /var/log/Xorg.0.log for errors?
Or when you stop X, try startx rather than restarting the service.
Byte Commander
  • 110,243
Jon Tucker
  • 117
