So I install this new driver because I wanted access to cuda.
Now, the only thing my computer does when booting is going to a black screen with an underscore flashing on the top-left corner. Before that point, I see rapidly the tty login screen but I don't have time to log there.
Any ideas what I should do about that?
Thanks in advance guys!
widgg
  • 121
Following @TrailRider link, I managed to solve this problem. Not sure exactly what did the thing, but I solved it.
1) be sure to purge any nvidia-current package!
2) if you install with the nVidia driver, run it like:
sudo sh NVIDIA-Linux-x86_64-319.49.run --uninstall
So that it will clear any bad things that was there
3) finally, just reinstall normally:
Now, I have access to cuda again. Thanks to everyone that took time to read this question and a special thanks to @TrailRider!
Zanna
  • 72,312
widgg
  • 121
First remove all nvidia packages:
sudo apt-get purge nvidia*
Then reinstall the current nvidia drivers:
sudo apt-get install nvidia-current
You can install the CUDA toolkit using:
sudo apt-get install nvidia-cuda-toolkit
see https://launchpad.net/ubuntu/+source/nvidia-cuda-toolkit
Joren
  • 5,074
