206
When using sudo to allow edits to files, I regularly get 'permission denied'.
For example, my mouse is jittery and sluggish, so I want to disable polling:
sudo echo "options drm_kms_helper poll=N">/etc/modprobe.d/local.conf
I'm prompted for a password, and then get:
bash: /etc/modprobe.d/local.conf: Permission denied
So I tried to do a temporary change to disable polling by using:
sudo echo N> /sys/module/drm_kms_helper/parameters/poll
Yet again the system responded with:
bash: /sys/module/drm_kms_helper/parameters/poll: Permission denied
Any ideas?
Jack
  • 4,029
7 Answers7
258
Output redirection (via the > operator) is done by the shell, not by echo. You have to login as root
sudo -i
Then you can use redirection
Otherwise you can run bash string with sudo
sudo bash -c "echo N> /sys/module/drm_kms_helper/parameters/poll"
shantanu
  • 8,835
90
The output redirection is done by the shell from which the command has been invoked. So, breaking everything into bits, here what is happening*:
  • shell invokes sudo echo "options drm_kms_helper poll=N", which executes sudo command with echo "options drm_kms_helper poll=N" command line
  • sudo asks for a password, opens superuser shell and invokes echo "options drm_kms_helper poll=N", which runs echo command passing it "options drm_kms_helper poll=N"
  • echo, running with root privileges, prints the string to its standard output.
  • echo command terminates, superuser shell exits, sudo terminates
  • the shell from which the command has been invoked collects the output and tries to redirect it to /etc/modprobe.d/local.conf, which is writeable only by root. It gets "permission denied" error.
For the ways to fix this see @shantanu answer.
(*) - while the above sequence helps to understand why the command fails, in reality things happen somewhat out-of-order: the original shell notices the redirection and tries to open the file for writing before invoking the sudo ... command. When opening the file fails the shell doesn't even invoke the command which was supposed to write to the file (thanks to @PanosRontogiannis for pointing this out).
Here's a quick test:
$ touch ./onlyroot.txt
$ sudo chown root:root ./onlyroot.txt
$ sudo bash -c "whoami | tee who.txt" > onlyroot.txt
bash: onlyroot.txt: Permission denied
In the test above the whoami | tee who.txt was going to create a file named who.txt containing the word "root". However, when the output redirection fails in the calling shell, "who.txt" file is also missing because the command was not invoked.
Sergey
  • 44,353
73
You can use a tee command like this:
sudo tee /sys/module/drm_kms_helper/parameters/poll <<<10
Or if its a command's output:
echo 10 | sudo tee /sys/module/drm_kms_helper/parameters/poll
If you had a situation where you wanted to append rather than overwrite the target file--that is, to make tee behave like >> rather than >--you would use tee -a.
Eliah Kagan
  • 119,640
Untitled
  • 1,468
19
An approach I haven't seen mentioned here is to simply execute the entire commandline in its own shell. The sudo manpage itself gives an example of this approach:
To make a usage listing of the directories in the /home partition. Note that this runs the commands in a sub-shell to make the cd and file redirection work.
$ sudo sh -c "cd /home ; du -s * | sort -rn > USAGE"
kojiro
  • 321
Another option is to use a temporary file. This is useful in a bash script.
temp=$(mktemp)
echo "Hello, world!" > $temp
sudo cp $temp /etc/wherever
sudo dd of=
To append as you want:
echo inbytes | sudo dd of=outfile oflag=append conv=notrunc
or to recreate the file from scratch:
Advantages:
Works because sudo forwards stdin to the command.
Create a one-line script from your command, then execute the script as sudo. For example:
  1. Use an editor to create a file; for example:
    nano my_script.sh
  2. In the editor, insert your shebang, and the command:
    #!/bin/bash
    echo "options drm_kms_helper poll=N" > /etc/modprobe.d/local.conf
  3. Save the file & exit the editor; e.g. ~/my_script.sh
  4. Make the file executable:
    chmod 755 ~/my_script.sh
  5. Run the script under sudo:
    sudo ./my_script.sh
muru
  • 207,228
Seamus
  • 698
