I'm trying to change content of system file, buy without success. chown by me. i m able to open and save file, but once o open again, it resets.
echo 5>/sys/class/drm/card0/device/pp_sclk_od
gives no error, but file stays the same. as far as i get file used by the system.
Please advice how to change it. thanks.
I want to build script to change couple files from same directory.
thanks
aleXela
  • 111
First, do not change ownership or permissions of system files, doing so can break ubuntu. Most are owned by root and keep them that way.
Second, if you have not already, read up on permissions and sudo
https://help.ubuntu.com/community/FilePermissions
https://help.ubuntu.com/community/RootSudo
These are important for security issues.
Third, rather than editing these files you can usually edit a configuration file somewhere.
Fourth run from a root shell:
sudo -i
And fifth, if you want to redirect with sudo use tee or similar
echo 5 | sudo tee >/sys/class/drm/card0/device/pp_sclk_od
See When using sudo with redirection, I get 'permission denied' for details
Panther
  • 104,528
