13
I have just installed Ubuntu 16.04 LTS on my Dell Latitude E6540 and my keyboard backlight is keeps going on after some time even after I switch them off using the shortcut keys (Fn+->).
Thanks in advance for any help.
Filbuntu
  • 13,891
6 Answers6
12
echo 2 | sudo tee /sys/devices/platform/dell-laptop/leds/dell\:\:kbd_backlight/brightness
Worked for me I have a new 2in1 Inspiron 7568.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
kleeman7
  • 139
12
Just purchased a 2016 Dell XPS13-9350. Wiped off Windows 10, with immense joy by the way, and installed Ubuntu 16.04 LTS and the Cinnamon desktop. This is a sweet laptop combo.
The default setting is to dim the keyboard back light after 10 seconds of no key press. This was driving me absolutely crazy because I fly a lot and want the back light to stay on longer.
The file /sys/devices/platform/dell-laptop/leds/dell\:\:kbd_backlight/stop_timeout contains the back light timeout value.
Answer 3 (above) did not work for me because the echo command did not work, even as root. Instead I did the following:
sudo nano /sys/devices/platform/dell-laptop/leds/dell\:\:kbd_backlight/stop_timeout
change the 10s on line-1 to 300s (Without quotes). This will change the timeout to 5 minutes. Change it to whatever you wish.
Save the file (Ctrl-O, Enter, Ctrl-X).
Hope this helps someone as frustrated with this as I was.
Anwar
  • 77,855
Sopwith
  • 121
I found fix in one of comments on launchpad bugtracker
Step 1: change system option
Edit file /etc/dbus-1/system.d/org.freedesktop.UPower.conf
change:
<allow send_destination="org.freedesktop.UPower"
       send_interface="org.freedesktop.UPower.KbdBacklight"/>
to:
<deny send_destination="org.freedesktop.UPower"
Step 2: execute command with system startup
add folowing lines to the file /etc/rc.local
#!/bin/sh -e
# Mask kernel module
sudo systemctl mask systemd-backlight@leds\:dell\:\:kbd_backlight.service
exit 0
It is really works.
Keyboard backligt works too, but not automatically, by pressing Fn-keys only.
PRIHLOP
  • 2,108
  • 16
  • 15
Another thing on Dell laptops (including my XPS 15, 9550) is that the backlight dims and goes off after 10 seconds idling.
There is a command that worked for me (Linux Mint 18 on a 9550, kernel 4.8) that allowed me choose the timeout :
sudo bash -c 'echo "60s" > /sys/class/leds/dell\:\:kbd_backlight/stop_timeout'
This is for a 60s timeout, which is sufficiant in my case. Of course, you can put anything here, like 3600s for an entire hour, which can comfortably relate to « stay on ».
I used to have my Dell Vostro 3560 keyboard-backlight constantly turned on after reboot, even if I had it turned off. The fix was in /etc/UPower/UPower.conf. I changed IgnoreLid=false to IgnoreLid=true. That helped.
Alex
I have run into this problem on Ubuntu 22.04.1 with Mate.
  • Pressing <Fn>+<Space> is not permanent because Mate overrides the backlight setting when the screen is unlocked.
  • Tweaking systemd does not help.
Solution
I have solved the problem by doing the following:
  1. Run gsettings list-recursively | grep --color kbd to find relevant settings. In the output, you will find these rows:
org.mate.power-manager kbd-backlight-battery-reduce true
org.mate.power-manager kbd-brightness-dim-by-on-battery 50
org.mate.power-manager kbd-brightness-dim-by-on-idle 75
org.mate.power-manager kbd-brightness-on-ac 100
  1. Change kbd-brightness-on-ac to 0 and kbd-backlight-battery-reduce to false by running:
gsettings set org.mate.power-manager kbd-brightness-on-ac 0
gsettings set org.mate.power-manager kbd-backlight-battery-reduce false
Now the keyboard backlight will stay off when you unlock the screen.
Student
  • 101
