I have a hdd automount program written.
The software uses ssh in order to issue requests against the target machine. The Idea is that a newly installed hdd is automatically added to fstab.
I have gotten everything working to the point where the fstab line enty is ready to be appended to the file.
I am trying to append like this in my software:
command.RunCommandSudo($"echo \"{mountstring}\" >> /etc/fstab");
resulting in an ssh query of the following format:
sudo echo "UUID=X /mnt/test ext4 defaults 0 1" >> /etc/fstab
=> Permission denied
how would be an apropriate way? I doubt the apropriate way for an automated software would be to go through a text editor such as nano?
julian bechtold
  • 785
  • 17
Another way is to use the tee command.
NAME
       tee - read from standard input and write to standard output and files
SYNOPSIS tee [OPTION]... [FILE]...
DESCRIPTION Copy standard input to each FILE, and also to standard output.
   -a, --append
          append to the given FILEs, do not overwrite
So, for your command you could do it this way:
echo "UUID=X /mnt/test ext4 defaults 0 1" | sudo tee -a /etc/fstab
Terrance
  • 43,712
Like this
sudo su -c "echo 'UUID=X /mnt/test ext4 defaults 0 1' >> /etc/fstab"
Mind that a script like this should be used by user root and not your admin so that would negate the use of sudo.
I am more into doing it like this:
grep -q '/mnt/test' /etc/fstab ||
printf 'UUID=X /mnt/test ext4 defaults 0 1\n' >> /etc/fstab
using user root to do this.
Rinzwind
  • 309,379
