Your command does not work because the redirection of the output (>/>>) is not performed by sudo. There are several ways to solve this. For example:
You can use pipe (|) and performed by sudo tee command with --append option:
echo /home/mpiuser/mpich1/bin | sudo tee -a /etc/environment
Another approach is to run the entire command as sudo:
sudo bash -c 'echo /home/mpiuser/mpich1/bin >> /etc/environment'
In result the content of /etc/environment will looks something like:
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
References:
EDIT 1:
However I think this new line in /etc/environment will do nothing by itself. To have some meaning this "path" must be appended to the value of $PATH envvar.
Ubuntu Documentation says that:
Variable expansion does not work in /etc/environment.
So to append /home/mpiuser/mpich1/bin to the value of $PATH, via single command, you can use this one:
cat /etc/environment | sed 's/\"$/:\/home\/mpiuser\/mpich1\/bin\"/' | sudo tee /etc/environment
Where: (1) cat /etc/environment will print the content of the file; (2) sed '...' will replace the last quote mark (") with :/home/mpiuser/mpich1/bin"; (3) sudo tee /etc/environment will rewrite the file.
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/mpiuser/mpich1/bin"
Please, scroll to the end.
References:
EDIT 2:
I did a little research and found few advices like this:
However, if you need to set that environment variable for all users, I
would still not recommend touching /etc/environment but creating a
file with the file name ending in .sh in /etc/profile.d. The
/etc/profile script and all scripts in /etc/profile.d are the
global equivalent of each user's personal ~/.profile and executed as
regular shell scripts by all shells during their initialization.
And this:
Please avoid modifing system files. Instead you should place an
executable script in /etc/profile.d (scripts in here got executed
for every user) to change $PATH value.
According to these advises, let's suppose that you want to create a file named mpich-path.sh which is placed in the directory /etc/profile.d/. This can be done by the command:
echo 'export PATH="$PATH:/home/mpiuser/mpich1/bin"' | sudo tee /etc/profile.d/mpich-path.sh
In result the content of the new file /etc/profile.d/mpich-path.sh will looks like this:
Logout and login back into the system and type echo $PATH to check the result.
EDIT 3:
I don't know about the other steps in the manual that you have follow, but apart from step 11, step 10 also does not seem completely clear.
This part:
export PATH=/home/mpiuser/mpich1/bin:$PATH # assigns a new value and exports the variable
export PATH # exports the variable
must be:
or just:
And it will produce the same result as step 11. So this part is unnecessary.
The new thing here is this part:
LD_LIBRARY_PATH="/home/mpiuser/mpich1/lib:$LD_LIBRARY_PATH"
export LD_LIBRARY_PATH
But, maybe, it can be included into the file - /etc/profile.d/mpich-path.sh - who we created above.
