I have just upgraded my ubuntu to 22.04 but the audio is not working. In the setting, the audio option has only "Dummy Output" and the test fails.
I have tried to do what is reported here and here but both do not work.
Thanks
This looks very similar to No sound output devices listed after upgrade from 21.10 to 22.04
that I could solve with:
sudo touch /usr/share/pipewire/media-session.d/with-pulseaudio
systemctl --user restart pipewire-session-manager
(credits go to https://askubuntu.com/a/1404159/139249)
Pipewire restart for Ubuntu >= 22.10
Pipewire became the default sound framework since Ubuntu 22.10, so now you need to:
systemctl --user restart pipewire.service
systemctl --user restart pipewire-pulse.service
Learned from: Is there another way to restart the sound system if pulseaudio/ALSA don't work?
The audio framework may change, but some things will never change.
For Ubuntu <= 22.04, try both pulseaudio --kill then pulseaudio --start
The dummy audio is coming up for me after suspend, and to fix it I needed both:
pulseaudio --kill
pulseaudio --start
Certain applications also needed to be restarted to pick up the new pulseaudio, e.g. VLC.
More details at: No sound on wake, Dummy Output always takes over. 'pulseaudio -k' the fix
Some check which audio server I'm using questions:
Tested on Ubuntu 22.04.1, Lenovo ThinkPad P51.
I have found this solution here.
Firstly, I have kill pulseaudio:
pulseaudio -k
After that, I have check if my laptop uses snd_hda_intel:
lsmod | grep snd_hda_intel
Luckily, it does.
I have, hence, run the following command:
echo "options snd-hda-intel model=generic" | sudo tee -a /etc/modprobe.d/alsa-base.conf
Finally, I have switched off and switched on my laptop. It seems that a simple reboot is not enough.
Best
I found the following to fix sound. This is not my fix but it worked because my hardware was Intel Pentium based. So if your hardware is Intel then edit this file:
sudo nano /etc/default/grub
Goto line: GRUB_CMDLINE_LINUX_DEFAULT=""
At the end Add to the following line enter the following: snd_hda_intel.dmic_detect=0
Press CTL+X, type "y" for yes, press enter to exit
Then type the following: sudo update-grub
Now reboot. You should have sound.
I tried everything else above, but then running
sudo modprobe snd-hda-intel
worked. I got immediately devices to show on: Settings->Sound->Output Devices instead of Dummy device.
I added the module name to /etc/modules to load it automatically on reboot.
For me worked the next commands:
$ sudo modprobe snd-hda-intel (from one of the posts here)
$ sudo apt-get install --reinstall alsa-base pulseaudio
$ sudo alsa force-reload
I found the solution here: https://aaroalhainen.medium.com/how-i-fixed-my-ubuntu-20-04-no-audio-dummy-output-issue-eaa525838e0d
In my case, I had the same issue after packages update on ubuntu 22.04, and was solved by updating preinstalled PipeWire to use ppa version. You can follow the installation instructions here to see if it helps: https://linuxconfig.org/how-to-install-pipewire-on-ubuntu-linux
UPDATE:
After a few reboots, it stopped working again. New error showed me "org.freedesktop.systemd1 exited with status 1", so I dig deeper and found my /run/user/1000 folder was owned by root (because of docker restart policy). I removed the folder and reboot the system.
I had the same issue and none of the suggestions here worked for me until clean installing Ubuntu 24.04
I actually upgraded from 22.04 to 23.04 to 24.04 before re-installing but this didn't resolve the issue for me. I had most likely messed up some configurations or firmware while trying to get the sound to work on 22.04 - thus, re-install did the trick.
My Ubuntu forum thread with some additional details: https://ubuntuforums.org/showthread.php?t=2492601
