I’m encountering an issue on Ubuntu 24.04 where PulseAudio displays 'Dummy Output,' and my soundcard isn’t being recognized.
I’ve tried downgrading the kernel from 6.8 to 6.5 as advised by the answer to Fixing No Sound (Dummy Output) Issue in Ubuntu 24.04 which also did not resolve the issue.
How can I fix this issue and get my soundcard recognized properly?
Malady
  • 292
axle
For 24.04.2:
Just keep resetting, it should work eventually? Running commands might help, or might just slow you down?
It might need a full power cycle instead of just "soft" Reset from the Power Off menu?
For 24.04.1:
Unlike in plain 24.04, the solution is now running this and resetting.
systemctl --user restart pipewire.service
From what this command tells me, I'm using PipeWire Pulse Audio, since everything else comes up with errors.
systemctl --user status pipewire{,-pulse} wireplumber
For 24.04:
Run the following then reset your computer, that's what fixed it for me, since I didn't want to downgrade:
systemctl --force --user --now enable wireplumber.service
Further info:
This seems to be a continuing issue from 22.04 onwards, since I found an answer to a 22.04 version of this problem, then looked up the error messages that I got from attempting and led me to this answer which got me to the code above that worked after a reset.
Malady
  • 292
