I just upgraded to Ubuntu 22.04 from 21.10 today. After upgrade, HDMI Audio setting is not playing any sound through TV Speakers. Video playback on Plex is also broken, stopping and starting and very jumpy. I assumed it was an issue with the upgrade, so I did a clean install of 22.04. Everything works as expected when using built in speakers, Plex video plays correctly and has sound. As soon as I change to HDMI audio output, I no longer get sound and playback on Plex breaks. This is a Dell 6540 laptop. I have swapped HDMI cables and get the same result. No issues with this laptop on 21.04 or 21.10.
We have fixed this bug here.
https://bugs.launchpad.net/ubuntu/+source/alsa-driver/+bug/1970050
sudo nano /etc/default/grub
Change:
GRUB_CMDLINE_LINUX=""
To:
GRUB_CMDLINE_LINUX="intel_iommu=on,igfx_off"
Save file and update grub:
sudo update-grub
reboot
- 122
I had no HDMI Audio output after a clean install of 22.04 LTS. Upgrading from 20.04, which had no problems with HDMI Audio. I run 22.04 on a Intel DH87RL with a 4770 (Haswell) CPU.
The GRUB edit that is reported to correct no HDMI audio output gave me a clue to try a different approach.
IOMMU requires CPU virtualization support. I toggled OFF 2 UEFI/BIOS settings for virtualization support on my motherboard.
This corrected my HDMI Audio issue.
I did a clean install of the 22.04 OS before I tested the HDMI Audio output.
The Pulseaudio pavucontrol app allowed me to "lock in" my HDMI audio config.
I had the same problem with my I5 Haswell. You'll need to edit grub.
sudo gedit /etc/default/grub
Change:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
To:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_iommu=on,igfx_off"
sudo update-grub
reboot
- 1
I had the same problem with no HDMI sound output after upgrade to 22.04 which worked fine on all previous ubntu versions but I found, (purely by chance), that switching the HDMI device off, (in my case my TV), and then switching it back on on meant I could select HDMI output in the settings, (which had previously been unavailable), and it worked fine. I'll leave others to figure out why that is but it seems to be a 'fix' anyway :)
The grub 'fix' didn't work for me.
