121
What constitutes protons? When I see pictures, I can't understand. Protons are made of quarks, but some say that they are made of 99% empty space. Also, in this illustration from Wikipedia, what's between the quarks?
Doorknob
  • 115
7 Answers7
231
Ah, I know this one!
What's in a proton?
A proton is really made of excitations in quantum fields (kind of like localized waves). Remember that. Any time you hear any other description of the composition of a proton, it's just some approximation of the behavior of quantum fields in terms of something people are likely to be more familiar with. We need to do this because quantum fields behave in very nonintuitive ways, so if you're not working with the full mathematical machinery of QCD (which is hard), you have to make some kind of simplified model to use as an analogy.
One of the more confusing things about quantum field excitations is that they react differently depending on how they are observed. More specifically, the only way to measure the properties of an excitation in a quantum field is to make it interact with another excitation and see how the excitations affect each other. Or in particle language, you have to hit the particle with another particle (the "probe") and see what comes out. Depending on the charge, energy, momentum and other properties of the probe, you can get various results.
People have been doing this for decades, and they've compiled the results into a few general conclusions. For example, in a slow collision, with very little energy involved, a proton acts like a single point particle. If we give the particles slightly more energy, the proton looks more like a blob with three points in it --- this is part of why it's often said that the proton consists of three quarks. (Incidentally, the reason you see images like the one you found on Wikipedia is that for a long time, people were colliding protons at the intermediate energies where they appear to behave as a group of three quarks.) If we give the colliding particles even more and more energy, the proton will appear to be an ever-more-dense amalgamation of all sorts of particles: quarks, antiquarks, gluons, photons, electrons, and everything else. We call these particle partons (because they're part of the proton).
The following diagram shows representative examples of the effective composition of the proton in different kinds of collisions. The vertical axis basically corresponds to collision energy, and the horizontal axis corresponds to the "resolving power" of the incident ("probe") particle. (Resolving power is basically transverse momentum, but I can't explain how that connection works without getting into more detail of quantum mechanics than I think is necessary.) The contents of each circle represents, roughly, a sample "snapshot" of how the proton behaves in a collision at the corresponding energy and resolving power. The exact numbers, locations, and colors of the dots aren't significant (except sort of in the bottom left), just note how they get larger or smaller and more or less numerous as you move around the plot.
kinematic diagram of proton composition
So for example, if you hit a proton with a beam of high-energy probes (top) that have weak resolving power (left), it behaves like a dense cluster of partons (quarks and gluons etc.), each of which is fairly large. Or if you hit the proton with a beam of low-energy probes (bottom) with high resolving power (right), it behaves like a sparse cluster of partons, each of which is small. If you hit it with a beam of low-energy (bottom), low-resolving-power (left) probes, it behaves like a collection of three particles.
Physicists describe this apparently-changing composition using parton distribution functions (PDFs), often denoted $f(x, Q^2)$. Under certain not-too-crazy assumptions, $f(x, Q^2)$ can be interpreted as the probability density of the probe interacting with a particular type of parton with a particular amount of momentum. Visually, $f(x, Q^2)$ is related to the number of particles in the circle at the corresponding $(x,Q)$ point on the plot (though again, the exact numbers are not chosen to exactly reflect reality). For more information on parton distributions, I would refer you to this answer of mine and the resources named therein, as well as this one.
What's the gray region?
In the preceding image, I displayed each snapshot of the proton as a set of partons (quarks and gluons etc.) uniformly distributed within a circle, as if the proton has a definite edge and there is nothing outside that edge. But in reality, that's not the case. The quantum fields that make up a proton gradually fade away to zero as you move further away from the center, giving the proton a fuzzy edge. So a (somewhat) more accurate sample snapshot would look something like this:
proton without a sharp edge
Notice that there are more dots near the center of the proton, and progressively fewer as you move toward the edge; this represents the fact that a probe which hits a proton dead-center is more likely to interact than a probe which hits it near the edge.
The ordinary parton distributions that I mentioned above, $f(x, Q^2)$, are part of a simplified model in which we ignore this fact and pretend that partons are distributed uniformly throughout space. But we can make a more complicated model that does take into account the fact that partons are clumped up toward the center of the proton. In such a model, instead of regular parton distributions, you get more complicated functions, called impact parameter-dependent parton distributions, and denoted $f(x, Q^2, b)$, where $b$ is the radial distance from the center at which the probe hits - the impact parameter.
There have been some theoretical studies showing that these impact parameter-dependent parton distributions trail off gradually as you go to large radii. For example, see figure 5 of this paper (arXiv) or figure 7 in this one (arXiv):
Impact parameter dependence of scattering amplitude
Here $N(y)$ is a quantity related to the parton distributions (specifically, it's the color dipole scattering amplitude), which kind of "condenses" the many different parton distributions into one quantity. (Huge oversimplification, but it's good enough for this.) You can then define the spatial extent of the proton as the region in which $N(y)$ is above, say, 5% of its maximum value. Or 10%. Or 50%. The exact number is somewhat arbitrary, but the point is, whatever number you pick, you'll wind up with a circle that encompasses the region in which the parton distribution function is large, kind of like this:
proton with fuzzy edge and with a circle behind it
This is roughly what the gray circle in the image from Wikipedia represents. It's a region with a size on the order of $1\text{ fm}$ (that's about $5\text{ GeV}^{-1}$ in natural units), where the chance of an incident particle (a probe) scattering off the proton is relatively significant. Equivalently, it's the region in which the parton distributions are large, and also the region in which the quantum fields that constitute the proton are much different from zero.
As you can guess, all this is pretty imprecise. You can make a more rigorous definition of the size of a proton by using the scattering cross section. You can also get a definition without using scattering, using the charge radius, which can be measured or calculated using various other methods. I won't go into those, as the details would be material for a whole separate question, but the results of all these methods come out to a radius a little less than $1\text{ fm}$.
Incidentally, this claim of a proton being 99% empty space is probably false using any reasonable definition. You might be thinking of atoms, where the volume in which the electron's quantum field has an appreciable value is much larger than the size of the electron itself, whatever it may be. People sometimes simplify that to say that the atom consists of a large fraction of empty space. But you can't really do the same with a proton, given the large number of particles in it and the strength of their interactions.
Emilio Pisanty
  • 137,480
David Z
  • 77,804
52
The illustration doesn't show the underlined physical reality. A proton is made up of 3 quarks, namely $uud$, but it is also constituted, as jinawee pointed out, of virtual quarks and antiquarks who are constantly being created and annihilated via strong force which is mediated by gluons, described by Quantum Chromodynamics (QCD).
The grey sphere in Wikipedia's site, shows the region where quarks make the proton, in other terms, if the wave-function shows the probability of finding a particle in a region of space, then this sphere shows the probability where you can find the essential quarks making up a proton.
45
You can't consider a proton just as three quarks (called valence quarks, because they determine the quantum numbers) because virtual quarks and antiquarks are constantly being created and anhilated via strong force. So a proton is more like a quark sea. In fact, this process gives most part of the proton's mass (the valence quarks are just the 2% of the mass).
It's something like this:
The lines that connect quarks are gluons (the force carrier particles of the strong interaction).
jinawee
  • 12,675
  • 60
  • 102
26
The question you are asking has been answered in terms of popularized description.
The real physics picture is not simple and depends a lot on a number of experimental measurements by many experiments. If you look at figure 9.18 of the link you will see that the composition of the proton changes according to the momentum transfer from the probing particle.
parton q2
Contrary to the statement that it is mainly empty space, it is not. Particles probing the proton do not sail through unscathed, they interact with the quarks and gluons that compose it and thus we get the parton functions in the figure. The reason it is not mostly empty is because Quantum Chromodynamics, contrary to the other forces does not diminish with distance, but increases, thus the constituents are tightly bound.
So the answer to "whats inside the proton" is "it depends on the way you look inside it". From outside, it has the quantum numbers assigned to it by the three valence quarks.
anna v
  • 236,935
12
The real problem here is that when things get really, really small, they don't behave like the world we see around us. That can make a lot of what goes on in that weird world quite hard to grasp.
The diagram is misleading. Protons aren't really round, grey blobs, and quarks aren't really little spheres that sit inside them. Down at the subatomic level, Quantum Mechanics rules.
One of the weird upshots of Quantum Mechanics is that really tiny things don't actually occupy a single space. Take a look at your hand. It's there, right? In one, single place. If you curl it into a fist, it takes up less space, and if you stretch it out, it takes up more. But it's always in one place.
Really tiny things don't work like this. Instead, they occupy many points in space at the same time. We usually draw diagrams where the actual positions of tiny things are represented like clouds: they're in lots of places, all at once.
Quarks are like this, too. They're held together by incredibly strong forces, but they're trying to get away from one another, too. Like when you're in a car with your parents on a long drive. What do I do on a long drive with my parents? I fidget. I couldn't tell you where I'll be - front seat, back seat - because I'm constantly moving around. But you know I'm somewhere inside the car, even if you can't tell me exactly where.
And so with quarks, with one twist: they really are in many different places at the same time. What we do know is that they're most likely stay within a boundary: in this case, the grey circle of the proton.
As for the 99% of empty space, the actual figure is much higher than that. Very little is actually 'made up' of matter (we usually call matter-like particles 'hadrons'). So why don't we fall through things all the time? Why doesn't my laptop slip through my desk, if it's mostly nothing? Well, because the forces between these tiny particles are tremendous, compared to their size (and, more importantly, compared to their mass). That allows them to stay a balanced distance from each other, and stops anything else from coming too close to them, or falling 'in between' the particles. When you catch a ball, the particles in your hand and the particles in the ball never even come close to 'touching', because the forces between particles are so strong. Instead, the ball is 'repulsed' from your hand. This repulsion balances against the ball's force due to gravity, so the ball stays where it is.
TL;DR: The diagram does the best it can at explaining how things work on the very very small-scale. Unfortunately, it's very misleading. The 'space between' particles is a) not really space, but 'point clouds' of possible particle positions (there's a mouthful), and b) it's forces between particles, rather than the particles themselves, that stop the 'empty space' in the proton from being something you could actually go through.
As some of the answers have pointed out, the "gray ball" shown in the picture is not really a physical entity in itself. It has to do more with the classical view that we have of subatomic particles as being a solid object, when in fact they are not. It's a representation of the average radius of the particle.
When you perform an experiment to detect the proton, you have a certain probability to find it inside the gray area, but also a small one of finding it outside. So a better way to show it would be to represent the ball with a lighter shade of gray as you are moving away from the centre of the particle. This would give a better notion of the fact that the particle is not a solid with defined edges. As you move away from the expected position (the centre of the gray zone), it is less and less probable to detect the proton.
legrojan
  • 278
The point is, that is not a picture of a proton; it's a schematic representation. You can see it as a Euler diagram that says that in the proton you have 3 valence quarks and some gluons.
By the way the exact constituents of a proton is still an open question.
Pete Oakey
  • 1,574
BiA
  • 201
