81
How to set custom keyboard shortcuts from terminal for different Linux versions?
Basically I want to know where Linux stores the keyboard shortcut files and how it can be edited.
On my research I found a file ~/.config/compiz-1/compizconfig but it was more or like encrypted when I tried to open it with nano.
Jacob Vlijm
  • 85,475
11 Answers11
83
Adding shortcut keybindings in two steps from the command line (14.04+)
Adding custom shortcuts from the command line can be done, but is a bit complicated; it needs to be done in a few steps per keybinding. On the other hand, it is pretty straightforward and can very well be scripted if you somehow want to do it from the command line (that was the question, right?).
Just like in your interface (System Settings > "Keyboard" > "Shortcuts" > "Custom Shortcuts"), Custom keyboard shortcuts are made from command line in two steps:
  1. create the keybinding by editing (adding to-) the list that is returned by the command:
    gsettings get org.gnome.settings-daemon.plugins.media-keys custom-keybindings
    The returned list looks like (if it were only one shortcut currently):
    ['/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/']
    Apply the edited list by the command:
    gsettings set org.gnome.settings-daemon.plugins.media-keys custom-keybindings "[<altered_list>]"
    (mind the double quotes)
    N.B. No need to say that the mention in the list (e.g. custom1, custom2) should be a unique one. If you script it, the script should prevent duplicates. In this case the edited list should look like e.g.:
    ['/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom1/']
    to add one keybinding: custom1
  2. set its properties:
    • name:
      gsettings set org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom1/ name '<newname>'
    • command:
      gsettings set org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom1/ command '<newcommand>'
    • Key combination (for example <Primary><Alt>g):
      gsettings set org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom1/ binding '<key_combination>'
Useful information can be found here
Example script to set a new custom shortcut
The script below can be used to set a new shortcut key combination from the command line. It can be used with the command (assuming the key combination is available):
python3 /path/to/script.py '<name>' '<command>' '<key_combination>'
An example:
To set a shortcut key combination to open gedit with the key combination Alt+7:
python3 /path/to/script.py 'open gedit' 'gedit' '<Alt>7'
The script:
#!/usr/bin/env python3
import subprocess
import sys
# defining keys & strings to be used
key = "org.gnome.settings-daemon.plugins.media-keys custom-keybindings"
subkey1 = key.replace(" ", ".")[:-1]+":"
item_s = "/"+key.replace(" ", "/").replace(".", "/")+"/"
firstname = "custom"
# get the current list of custom shortcuts
get = lambda cmd: subprocess.check_output(["/bin/bash", "-c", cmd]).decode("utf-8")
array_str = get("gsettings get "+key)
# in case the array was empty, remove the annotation hints
command_result = array_str.lstrip("@as")
current = eval(command_result)
# make sure the additional keybinding mention is no duplicate
n = 1
while True:
    new = item_s+firstname+str(n)+"/"
    if new in current:
        n = n+1
    else:
        break
# add the new keybinding to the list
current.append(new)
# create the shortcut, set the name, command and shortcut key
cmd0 = 'gsettings set '+key+' "'+str(current)+'"'
cmd1 = 'gsettings set '+subkey1+new+" name '"+sys.argv[1]+"'"
cmd2 = 'gsettings set '+subkey1+new+" command '"+sys.argv[2]+"'"
cmd3 = 'gsettings set '+subkey1+new+" binding '"+sys.argv[3]+"'"
for cmd in [cmd0, cmd1, cmd2, cmd3]:
    subprocess.call(["/bin/bash", "-c", cmd])
How to use:
Paste the script into an empty file, save it as set_customshortcut.py, run it as explained above.
Some of the mostly used key mentions (found experimentally, looking into the changes the GUI way made into the binding value):
Super key:                 <Super>
Control key:               <Primary> or <Control>
Alt key:                   <Alt>
Shift key:                 <Shift>
numbers:                   1 (just the number)
Spacebar:                  space
Slash key:                 slash
Asterisk key:              asterisk (so it would need `<Shift>` as well)
Ampersand key:             ampersand (so it would need <Shift> as well)
a few numpad keys:
Numpad divide key (`/`):   KP_Divide
Numpad multiply (Asterisk):KP_Multiply
Numpad number key(s):      KP_1
Numpad `-`:                KP_Subtract
etc.
weshouman
  • 113
Jacob Vlijm
  • 85,475
21
There is plain a simple way of doing that using dconf :
dconf write /org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/command "'move-window.sh'"
dconf write /org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/binding "'<Primary><Alt>Page_Down'"
dconf write /org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/name "'move-window'"
Using gsettings :
gsettings set org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/ name "'move-window'"
gsettings set org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/ binding "'<Primary><Alt>Page_Down'"
gsettings set org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/ command "'/usr/local/bin/move-window.sh'"
You need to increase number in the custom0part for adding more bindings, ie. custom1, custom2, etc.
To make it permanent, just add it to .bash_profile or a similar script that is ran by login shells. Just don't do it for non-login shells .bashrc because from my experience these dconf and gsettings slow it down significantly. Changing/Adding 30 bindings takes a second ! You don't want this in non-login shell (.bashrc)!
lisak
  • 343
10
All the custom keyboard shortcuts settings are stored in the dconf database.
You can easily access them with dconf-editor:
sudo apt-get install dconf-editor
Then go to the following dconf path in the editor:
Adding shortcut keybindings from the command line in 12.04
To prevent the accepted answer to become too extensive, posting a separate solution for 12.04.
Until (and including) 12.04, custom keybindings are not stored in the dconf database, but in ~/.gconf/desktop/gnome/keybindings (in an xml file, in subfolders like custom0 etc).
The script below creates the xml file and its containg folder, automatically named correctly.
How to use
  1. Paste the script into an empty file, save it as set_customshortcuts_12.py
  2. Run it with the command:
    python /path/to/set_customshortcuts_12.py <name> <command> <key1> <key2> <key3>
    key3 is optional, commands can be for example:
    python /path/to/set_customshortcuts_12.py run_browser firefox Primary 7
    or
    python /path/to/set_customshortcuts_12.py run_texteditor gedit Primary Alt 3
Notes
  • note that the naming of the keys is different from editing gsettings. The keys are named like they show in System Settings > "Keyboard" > "Shortcuts" > "Custom Shortcuts", as far as I can see.
  • I tested the script on 12.04 under VirtualBox; it needed a log out/in for the changes to take place.
import os
import sys
home = os.environ["HOME"]
name = sys.argv[1]
command = sys.argv[2]
keys = sys.argv[3:]
keyfile = [
    '<?xml version="1.0"?>',
    '<gconf>',
    '\t<entry name="action" mtime="1427791732" type="string">',
    '\t\t<stringvalue>'+command+'</stringvalue>',
    '\t</entry>',
    '\t<entry name="name" mtime="1427791732" type="string">',
    '\t\t<stringvalue>'+name+'</stringvalue>',
    '\t</entry>',
    '\t<entry name="binding" mtime="1427791736" type="string">',
    '\t</entry>',
    '</gconf>',
if len(keys) == 2:
    keyfile.insert(9, '\t\t<stringvalue>&lt;'+keys[0]+'&gt;'+keys[1]+'</stringvalue>')
else:
    keyfile.insert(9, '\t\t<stringvalue>&lt;'+keys[0]+'&gt;&lt;'+keys[1]+'&gt;'+keys[2]+'</stringvalue>')
n = 0
while True:
    check = home+"/"+".gconf/desktop/gnome/keybindings/custom"+str(n)
    if os.path.exists(check):
        n = n+1
    else:
        newdir = check
        newfile = check+"/"+"%gconf.xml"
        break
os.makedirs(newdir)
with open(newfile, "wt") as shortcut:
    for l in keyfile:
        shortcut.write(l+"\n")
Jacob Vlijm
  • 85,475
Save custom keyboard shortcuts
You can save/backup/export custom shortcuts/keybidings using just dconf and sed
Export
dconf dump / | sed -n '/\[org.gnome.settings-daemon.plugins.media-keys/,/^$/p' > custom-shortcuts.ini # Export
Import
dconf load / < custom-shortcuts.ini # Import
  • To backup you might want to use custom-shortcuts-$(date -I).ini
  • Note that dconf by default reads the user-db and only dumps non-default values (bold in dconf-editor)
  • Only for the added custom shortcuts
  • Based on Ciro's answer (also here)
  • Test if it's working by resetting to defaults this path before importing
    gsettings reset-recursively org.gnome.settings-daemon.plugins.media-keys
  • The same way you can backup for example a GNOME Shell extension setup:
    dconf dump / | sed -n '/\[org.gnome.shell.extensions.system-monitor\]/,/^$/p' > extensions-system-monitor-$(date -I).conf
Pablo Bianchi
  • 17,371
I gave up using dconf and tweak tool, I use kbindkeys with ~/.xbindkeysrc and put all my custom keyboard shortcuts, it is much more portable.
  1. First install xbindkeys $ sudo apt install xbindkeys
  2. Generate default .xbindkeysrc on the first time only, on the next time copy them to your home. $ xbindkeys --defaults > ~/.xbindkeysrc
  3. Put your shortkeys on .xbindkeysrc, one example, use Ctrl+Shift+F to skip to the next music on spotify:
    "dbus-send --print-reply --dest=org.mpris.MediaPlayer2.spotify /org/mpris/MediaPlayer2 org.mpris.MediaPlayer2.Player.Next"
          m:0x19 + c:41
  4. Other ex call gnome-calculator with Ctrl+Alt+Super+c put the line above in .xbindkeysrc:
          Control+Alt+Mod2+Mod4 + c
The xbindkeys format is easy, first line is the command and second line is the shortkey.
To discover the shortkey, use: $ xbindkeys -k and press the keys.
Remember to restart xbindkeys when add new shortkeys.
Pablo Bianchi
  • 17,371
You can set a new custom shortcut without a python script, by using sed. You just have to set name, binding and action to your choice in the following script:
name="myaction"
binding="<CTRL><ALT>v"
action="/usr/local/bin/myaction"
media_keys=org.gnome.settings-daemon.plugins.media-keys
custom_kbd=org.gnome.settings-daemon.plugins.media-keys.custom-keybinding
kbd_path=/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/$name/
new_bindings=`gsettings get $media_keys custom-keybindings | sed -e"s>'\]>','$kbd_path']>"| sed -e"s>@as \[\]>['$kbd_path']>"`
gsettings set $media_keys custom-keybindings "$new_bindings"
gsettings set $custom_kbd:$kbd_path name $name
gsettings set $custom_kbd:$kbd_path binding $binding
gsettings set $custom_kbd:$kbd_path command $action
mmai
  • 1,482
Wrote a script for that. See below.
See the usage in the creatShortcut invocation.
export nextShortcutId=0
function creatShortcut() {
    name="$1"
    commandToRun="$2"
    binding="$3"
    path="/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom${nextShortcutId}"
    nextShortcutId=$nextShortcutId+1
    dconf write "$path/name" "'""$name""'"
    dconf write "$path/command" "'""$commandToRun""'"
    dconf write "$path/binding" "'""$binding""'"
# dconf write /org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/binding '"<Primary><Shift>exclam"'
creatShortcut 'copyq show' 'copyq show' '<Primary><Shift>exclam'
creatShortcut 'System Monitor' 'gnome-system-monitor' '<Primary><Alt>m'
creatShortcut 'Suspend' 'systemctl suspend -i' '<Super>d'
creatShortcut 'Volume Up' 'amixer -D pulse sset Master 5%+' '<Super>Page_Up'
creatShortcut 'Volume Down' 'amixer -D pulse sset Master 5%-' '<Super>Page_Down'
overallbindings=""
for ((i = 0 ; i < $nextShortcutId ; i++ ));
do
    overallbindings="$overallbindings, '$customindingPathPrefix$i/'"
done
overallbindings="[${overallbindings:2}]" # Delete the first 2 chars: " ," - space and comma
# echo $overallbindings
# Update the list of bindings for the shortcuts to work
dconf write /org/gnome/settings-daemon/plugins/media-keys/custom-keybindings "$overallbindings"
# dconf write /org/gnome/settings-daemon/plugins/media-keys/custom-keybindings "['/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom1/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom2/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom3/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom4/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom5/']"
I found the answer posted by @JacobVlijm very useful, especially the script. I ported the code to bash. I don’t think this function is perfect, it might contain some bugs, however, it works for me.
Don’t expect me to update this script here. You can find the latest version of the script (and all its revisions) here.
function set_shortcuts(){
    # Usage: set_shortcuts [name] [command] [shortcut]
    unset num i name command shortcut value test value_new
    local name="$1"
    local command="$2"
    local shortcut="$3"
    local value=$(gsettings get org.gnome.settings-daemon.plugins.media-keys custom-keybindings)
    local test=$(echo $value | sed "s/\['//;s/', '/,/g;s/'\]//" - | tr ',' '\n' | grep -oP ".*/custom\K[0-9]*(?=/$)")
    if [ "$(echo "$value" | grep -o "@as")" = "@as" ]; then
        local num=0
        local value_new="['/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom${num}/']"
    else
        local i=1
        until [ "$num" != "" ]; do
            if [ "$(echo $test | grep -o $i)" != "$i" ]; then
                local num=$i
            fi
            i=$(echo 1+$i | bc);
        done
        local value_new=$(gsettings get org.gnome.settings-daemon.plugins.media-keys custom-keybindings | sed "s#']\$#', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom${num}/']#" -)
    fi
    gsettings set org.gnome.settings-daemon.plugins.media-keys custom-keybindings "$value_new"
    gsettings set org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom${num}/ name "$name"
    gsettings set org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom${num}/ command "$command"
    gsettings set org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom${num}/ binding "$shortcut"
Here is a Python script which uses PyGObject bindings instead of calling gsettings and parsing the output. When a keybinding of the same name already exists, it replaces it instead of adding a duplicate.
import sys
from gi.repository import Gio, GLib
media_keys_schema = "org.gnome.settings-daemon.plugins.media-keys" custom_keybinding_schema = "org.gnome.settings-daemon.plugins.media-keys.custom-keybinding" keybinding_path_prefix = "/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/"
usage_message = '''Usage: {cmd} <name> <command> <binding>
Example: {cmd} "Open gedit" "gedit" "<Shift><Ctrl>G" '''.format(cmd=sys.argv[0])
def main(): if len(sys.argv) < 4: sys.exit(usage_message) name = sys.argv[1] command = sys.argv[2] binding = sys.argv[3]
settings = Gio.Settings(schema=media_keys_schema)
binding_paths = settings.get_value(&quot;custom-keybindings&quot;).unpack()  # type: list[str]
# Figure out which path to use for the new binding. If a binding
# of the same name already exists, we replace it.
path = find(binding_paths, name)
if not path:
    # Use the first gsettings path that doesn't exist yet
    n = 0
    path = keybinding_path_prefix + f&quot;custom{n}/&quot;
    while path in binding_paths:
        n += 1
# Create the new keybinding
setting = Gio.Settings(schema=custom_keybinding_schema, path=path)
setting.set_string(&quot;name&quot;, name)
setting.set_string(&quot;command&quot;, command)
setting.set_string(&quot;binding&quot;, binding)
setting.sync()
if path not in binding_paths:
    # Add the new keybinding to the list of custom keybindings
    binding_paths.append(path)
    settings.set_value(&quot;custom-keybindings&quot;, GLib.Variant(&quot;as&quot;, binding_paths))
    setting.sync()
def find(binding_paths: list[str], name: str) -> str: for path in binding_paths: setting = Gio.Settings(schema=custom_keybinding_schema, path=path) setting_name = setting.get_value("name").unpack() if setting_name == name: return path
if name == "main": main()
As other have pointed out in comments the accepted answer using gsettings set did not work for me on Ubuntu 24.04 LTS. The dconf commands however did worked. So I adapted @Jacob Vlijm scripts to use the dconf commands.
import subprocess
import sys
key = "/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings" firstname = "custom"
get = lambda cmd: subprocess.check_output(["/bin/bash", "-c", cmd]).decode("utf-8") array_str = get("dconf read " + key)
command_result = array_str.lstrip("@as") current = eval(command_result)
n = 0 while True: new = key + "/" + firstname + str(n) + "/" if new in current: n = n+1 else: break
current.append(new)
cmd0 = 'dconf write ' + key + ' "' + str(current).replace(' ', '') + '"' cmd1 = 'dconf write ' + new + "name &quot;'" + sys.argv[1] + "'&quot;" cmd2 = 'dconf write ' + new + "command &quot;'" + sys.argv[2] + "'&quot;" cmd3 = 'dconf write ' + new + "binding &quot;'" + sys.argv[3] + "'&quot;"
for cmd in [cmd0, cmd1, cmd2, cmd3]: subprocess.call(["/bin/bash", "-c", cmd])
This must be called the same way as Jacob's script :
