This answer by Jacob Vlijm is an excellent guide to those wishing to add custom keybindings en masse, via the command line.
There are limits, however, to what's accepted as a valid binding. Shift+p for example, is something that you can absolutely set a custom keybinding to, but it won't actually function. For a custom binding to qualify as valid (and so perform the command when pressed), I believe the binding needs to contain Primary (Control) and/or Alt (plus some normal key, like k). Also, I'm not certain whether a binding can be made to distinguish between left and right; I suspect it can't. I suspect there is no Shift_L or Alt_R, but I'm not certain on that, and hope to be wrong.
Is there a known alternative to dconf's key binding functionality? dconf is perfectly fine for nearly all cases and users, I expect; I'm just being difficult and so want to know.
DK Bose
  • 44,553
John R
  • 13
There are alternatives to dconf's binding functionality if you run Gnome on X-server. You could use xbindkeys or sxhkd, daemons that are configured using a text file, and can be loaded automatically on log in. Both will work well in Gnome running on X, but may not work on Wayland.
You can assign your custom commands to Shift+key keys. However, these utilities do not allow to discriminate between left and right modifier keys.
vanadium
  • 97,564
