I have dual booted my Windows 8 laptop with Ubuntu 14.04. The wifi driver is Realtek rtl8723be. It didn't use to work but I updated the kernel to 3.18 and reinstalled the driver and that seemed to solve the problem for a few hours. Then it would be connected for around 30 minutes and then the connection would stop, even though the icon on the system tray would still indicate it's connected. The only thing that works is restarting the computer but then, again, after 30 minutes the connection stops.
I was having these problem with rtl8723be on linux mint 17, and mint17.1. The same procedure should work on ubuntu 14.04 and derivates.
I had to install new module for realtek wifi cards where they solved the constant disconnects:
install required packages
sudo apt-get install build-essential gitgit clone new realtek wifi modules
git clone https://github.com/lwfinger/rtlwifi_new/enter the directory
cd rtlwifi_newbuild it
makeinstall
sudo make install
Now you can reboot or unload/load modules
unload modules
sudo modprobe -r rtl8723beload new module
sudo modprobe rtl8723beif it still doesn't work, try the solution from this post
echo "options rtl8723be fwlps=0" | sudo tee /etc/modprobe.d/rtl8723be.conf
Note: After each kernel update, you need to rebuild the modules. That is,
After every kernel update:
cd rtlwifi_new
Clean previous builds
make clean
Update git repository
git pull
Compile
make clean && make
Install
sudo make install
EDIT: It seems as of kernel 4.17 kernel APIs have changed: Note: If your kernel is 4.17 or newer, AND your card is not an RTL8723DE, then you should NOT be using the external driver. The built-in one is the same. source: https://github.com/lwfinger/rtlwifi_new/
- 701
My friend's HP laptop wouldn't display the available Wi-Fi networks.
So I followed the steps from Miodrag Prelec's answer till echo "options rtl8723be fwlps=0" | sudo tee /etc/modprobe.d/rtl8723be.conf
Then, I did
Then either of:
sudo modprobe rtl8723be ant_sel=1
sudo modprobe rtl8723be ant_sel=2
(whichever works)
After doing this it would list the Wi-Fi signals in the menu.
So I added these lines to /etc/rc.local (above exit 0) so that it would run each time my laptop boots up.
sleep 10
Note: change ant_sel=1 to ant_sel=2 if required.
- 379
Run the following command in terminal
echo "options rtl8723be fwlps=N ips=N" | sudo tee /etc/modprobe.d/rtl8723be.conf
as this will disable some of the power management of the card and usually helps.
And then you need to reboot or manually reload the driver
sudo modprobe -rv rtl8723be
sudo modprobe -v rtl8723be
This was found in ubuntuforums. Varunendra is very good troubleshooting the realtek cards.
I faced a similar situation, I took the suggestions available on various sites, and created this script which works for me.
Here it is on GitHub
To clone the repo, run:
git clone https://github.com/tarunbatra/fixRTL8723BE
cd to the project root, then run bash install.sh. Here's the script for reference:
#!/usr/bin env bash
REPO="https://github.com/lwfinger/rtlwifi_new"
CONFIG_DIR=`pwd`
checkGit() {
if git --version &> /dev/null; then
echo "Git found"
else
echo "Git not found"
fi
installGit() {
echo "Installing git\n"
sudo apt-get install git >> /dev/null
cloneRepo() {
echo "Downloading latest drivers from $REPO"
if git clone $REPO /tmp/rtlwifi_new_$$; then
echo "Drivers downloaded successfully"
else
echo "Download couldn't be completed. Exiting"
exit 1
fi
installDrivers() {
cd /tmp/rtlwifi_new_$$ || (echo "Drivers not found"; exit 1)
echo "Building drivers"
if make && sudo make install; then
echo "Drivers built successfully"
else
echo "Drivers couldn't be built. Exiting"
exit 1
fi
configureWiFi() {
echo "Configuring the WiFi settings"
cd $1
if (cat ./setup.conf | sudo tee /etc/modprobe.d/rtl8723be.conf); then
echo "WiFi settings configured"
else
echo "Wifi settings couldn't be configured"
fi
restartWiFi() {
echo "Restarting WiFi"
if sudo modprobe -r rtl8723be && sudo modprobe rtl8723be; then
echo "WiFi restarted"
else
echo "Couldn't restart WiFi"
fi
echo "Fixing Wifi"
checkGit || installGit
cloneRepo $REPO
installDrivers
configureWiFi $CONFIG_DIR
restartWiFi
echo "Your WiFi is fixed. Enjoy!"
echo "If this doen't help, try changing rtl8723be.conf and repeating the process"
exit 0
