I have updated the Ubuntu version to 16.04. Also I've tried a bunch of different solutions as those answering these questions for example:
lenovo e540 RTL8723be wifi not working
Wifi problems with rtl8723be in Ubuntu 14.04
Wifi not working on Realtek rtl8723be wifi adapter
And none of them has worked. Please, if someone can help I'll appreciate it a lot.
The network command sudo lshw -C network :
*-network
description: Ethernet interface
product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:08:00.0
logical name: enp8s0
version: 07
serial: 3c:a8:2a:7b:fb:8c
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8106e-1_0.0.1 06/29/12 ip=192.168.1.47 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:41 ioport:4000(size=256) memory:b2600000-b2600fff memory:b2400000-b2403fff
*-network UNCLAIMED
description: Network controller
product: RTL8723BE PCIe Wireless Network Adapter
physical id: 0
bus info: pci@0000:09:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: latency=0
resources: ioport:3000(size=256) memory:b2500000-b2503fff
The lspci | grep -i network command :
09:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
