Ok been on this for a couple of days.Initially when I installed ubuntu 14.04 lts wifi was not working at all.But after some fixes I made it work although it's still not very stable and is slow. I have tried in the following order:
- Installing the new driver according to the first answer given on this page Unstable WiFi connection Ubuntu 14.04 - Lenovo G40-70 rtl8723be
- Installing another driver according to the first answer given on this page Wifi problems with rtl8723be in Ubuntu 14.04
- Than upgrading my kernel to 3.16.0-031600-generic.
- Than applying
echo "options rtl8723be fwlps=0" | sudo tee /etc/modprobe.d/rtl8723be.confaccording to information given on https://wiki.archlinux.org/index.php/Wireless_network_configuration#rtl8723ae.2Frtl8723be
It's not that wifi is not working at all but it is working really slow to the point of frustation. Output of lspci:
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Broadwell-U Integrated Graphics (rev 09)
00:03.0 Audio device: Intel Corporation Broadwell-U Audio Controller (rev 09)
00:04.0 Signal processing controller: Intel Corporation Broadwell-U Camarillo Device (rev 09)
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03)
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
00:1b.0 Audio device: Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #1 (rev e3)
00:1c.2 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #3 (rev e3)
00:1c.5 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #6 (rev e3)
00:1d.0 USB controller: Intel Corporation Wildcat Point-LP USB EHCI Controller (rev 03)
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03)
00:1f.3 SMBus: Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
00:1f.6 Signal processing controller: Intel Corporation Wildcat Point-LP Thermal Management Controller (rev 03)
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 07)
0d:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
Output of iw dev wlan0 station dump:
Station c4:e9:84:87:e1:86 (on wlan0)
inactive time: 48 ms
rx bytes: 3331226
rx packets: 15891
tx bytes: 1163486
tx packets: 4703
tx retries: 0
tx failed: 0
signal: -74 dBm
signal avg: -73 dBm
tx bitrate: 150.0 MBit/s MCS 7 40Mhz short GI
authorized: yes
authenticated: yes
preamble: long
WMM/WME: yes
MFP: no
TDLS peer: no
Any help would be much appreciated.
Edit 12/05/2015:
I've just upgraded to 16.04.Everything is working great except wifi. Problem remains the same.Wifi remains connected but works really slow.Probably slower than before.So the outputs are:
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 07)
and of iw dev wlan0 station dump is:
inactive time: 2404 ms
rx bytes: 1351602
rx packets: 8268
tx bytes: 524504
tx packets: 1874
tx retries: 0
tx failed: 0
signal: -66 dBm
signal avg: -66 dBm
tx bitrate: 150.0 MBit/s MCS 7 40MHz short GI
rx bitrate: 1.0 MBit/s
authorized: yes
authenticated: yes
preamble: long
WMM/WME: yes
MFP: no
TDLS peer: no
