I am trying to make my WiFi connection working on Ubuntu 16.04 (the same was happening with Ubuntu 14.04). I've already tried different solutions and reinstalled Ubuntu more than 5 times. Here are my results:
It seems that my network adapter RTL8723BE is giving problems to Ubuntu users for a very long time.
I followed the solution presented here https://askubuntu.com/a/543626/250716:
sudo -i
echo "options rtl8723be fwlps=0"  >  /etc/modprobe.d/rtl8723be.conf
modprobe -r rtl8723be
modprobe rtl8723be
exit
and my wifi started to work but it is now super slow (way faster on Windows). I also tried this one:
echo "options rtl8723be ant_sel=2"  | sudo tee /etc/modprobe.d/rtl8723be.conf
Same thing, wifi works but super slow.
I tried installing new drivers as suggested by some solutions: Wifi problems with rtl8723be in Ubuntu 14.04
sudo apt-get install build-essential git
git clone https://github.com/lwfinger/rtlwifi_new/
cd rtlwifi_new
make
install
sudo make install
and I also tried these drivers:
sudo add-apt-repository ppa:hanipouspilot/rtlwifi
sudo apt-get update
sudo apt-get install rtlwifi-new-dkms linux-firmware
In both situations the wireless connection disappears from Ubuntu as you can see in the image below:
This image shows that I dont have wifi
I also have the PCIe bus error messages described here: PCIe bus error messages on boot and shutdown it seems that the network adaptor RTL8723BE is a real pain!!
My laptop is brand new HP Pavillon Gaming Notebook. I really need Ubuntu for my Work. All the help is welcome.
Information about my system:
joao
    description: Computer
    width: 64 bits
    capabilities: smbios-2.8 vsyscall32
  *-core
       description: Motherboard
       physical id: 0
     *-memory
          description: System memory
          physical id: 0
     *-cpu
          product: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
          vendor: Intel Corp.
          physical id: 1
          bus info: cpu@0
          capacity: 3500MHz
          width: 64 bits
          capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch epb intel_pt tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt xsaveopt xsavec xgetbv1 dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp cpufreq
     *-pci
          description: Host bridge
          product: Sky Lake Host Bridge/DRAM Registers
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 07
          width: 32 bits
          clock: 33MHz
        *-pci:0
             description: PCI bridge
             product: Sky Lake PCIe Controller (x16)
             physical id: 1
             bus info: pci@0000:00:01.0
             version: 07
             width: 32 bits
             clock: 33MHz
             capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:122 ioport:5000(size=4096) memory:93000000-93ffffff ioport:80000000(size=301989888)
           *-display
                description: 3D controller
                product: GM107M [GeForce GTX 950M]
                vendor: NVIDIA Corporation
                physical id: 0
                bus info: pci@0000:01:00.0
                version: a2
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list
                configuration: driver=nouveau latency=0
                resources: irq:130 memory:93000000-93ffffff memory:80000000-8fffffff memory:90000000-91ffffff ioport:5000(size=128)
        *-display
             description: VGA compatible controller
             product: Intel Corporation
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 06
             width: 64 bits
             clock: 33MHz
             capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
             configuration: driver=i915_bpo latency=0
             resources: irq:131 memory:92000000-92ffffff memory:a0000000-afffffff ioport:6000(size=64)
        *-generic:0
             description: Signal processing controller
             physical id: 4
             bus info: pci@0000:00:04.0
             version: 07
             width: 64 bits
             clock: 33MHz
             capabilities: msi pm bus_master cap_list
             configuration: driver=proc_thermal latency=0
             resources: irq:16 memory:94320000-94327fff
        *-usb
             description: USB controller
             product: Sunrise Point-H USB 3.0 xHCI Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 31
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:126 memory:94300000-9430ffff
           *-usbhost:0
                product: xHCI Host Controller
                vendor: Linux 4.4.0-21-generic xhci-hcd
                physical id: 0
                bus info: usb@2
                logical name: usb2
                version: 4.04
                capabilities: usb-3.00
                configuration: driver=hub slots=8 speed=5000Mbit/s
           *-usbhost:1
                physical id: 1
                bus info: usb@1
                logical name: usb1
                version: 4.04
                capabilities: usb-2.00
                configuration: driver=hub slots=16 speed=480Mbit/s
              *-usb:0
                   description: Video
                   product: HP Truevision HD
                   vendor: Generic
                   physical id: 3
                   bus info: usb@1:3
                   version: 0.03
                   serial: DETGB01BI9E3L7
                   configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
              *-usb:1
                   description: Bluetooth wireless interface
                   product: Bluetooth Radio
                   vendor: Realtek
                   physical id: 7
                   bus info: usb@1:7
                   version: 2.00
                   serial: 00e04c000001
                   capabilities: bluetooth usb-2.10
                   configuration: driver=btusb maxpower=500mA speed=12Mbit/s
        *-generic:1 UNCLAIMED
             product: Sunrise Point-H Thermal subsystem
             physical id: 14.2
             bus info: pci@0000:00:14.2
             version: 31
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: latency=0
             resources: memory:94332000-94332fff
        *-communication
             description: Communication controller
             product: Sunrise Point-H CSME HECI #1
             physical id: 16
             bus info: pci@0000:00:16.0
             version: 31
             width: 64 bits
             clock: 33MHz
             configuration: driver=mei_me latency=0
             resources: irq:132 memory:94333000-94333fff
        *-storage
             description: SATA controller
             product: Sunrise Point-H SATA Controller [AHCI mode]
             physical id: 17
             bus info: pci@0000:00:17.0
             version: 31
             width: 32 bits
             clock: 66MHz
             capabilities: storage msi pm ahci_1.0 bus_master cap_list
             configuration: driver=ahci latency=0
             resources: irq:128 memory:94330000-94331fff memory:94336000-943360ff ioport:6080(size=8) ioport:6088(size=4) ioport:6060(size=32) memory:94334000-943347ff
        *-pci:1
             product: Sunrise Point-H PCI Express Root Port #5
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: f1
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             resources: irq:123 ioport:7000(size=4096) memory:94200000-942fffff ioport:7c900000(size=2097152)
           *-generic
                description: Unassigned class
                product: Realtek Semiconductor Co., Ltd.
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:07:00.0
                version: 01
                width: 32 bits
                clock: 33MHz
                configuration: driver=rtsx_pci latency=0
                resources: irq:127 memory:94200000-94200fff
        *-pci:2
             product: Sunrise Point-H PCI Express Root Port #6
             physical id: 1c.5
             bus info: pci@0000:00:1c.5
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:124 ioport:4000(size=4096) memory:94100000-941fffff
           *-network
                description: Wireless interface
                product: RTL8723BE PCIe Wireless Network Adapter
                physical id: 0
                bus info: pci@0000:08:00.0
                logical name: wlo1
                version: 00
                serial: 18:4f:32:a1:aa:03
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=rtl8723be driverversion=4.4.0-21-generic firmware=N/A ip=192.168.1.4 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
                resources: irq:17 ioport:4000(size=256) memory:94100000-94103fff
        *-pci:3
             product: Sunrise Point-H PCI Express Root Port #7
             physical id: 1c.6
             bus info: pci@0000:00:1c.6
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:125 ioport:3000(size=4096) memory:94000000-940fffff
           *-network
                description: Ethernet interface
                product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
                physical id: 0
                bus info: pci@0000:09:00.0
                logical name: eno1
                version: 0a
                serial: b0:5a:da:d5:2e:33
                capacity: 100Mbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8107e-2_0.0.2 02/26/15 ip=192.168.1.6 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
                resources: irq:129 ioport:3000(size=256) memory:94004000-94004fff memory:94000000-94003fff
        *-isa
             description: ISA bridge
             product: Sunrise Point-H LPC Controller
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 31
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master
        *-memory UNCLAIMED
             description: Memory controller
             product: Sunrise Point-H PMC
             physical id: 1f.2
             bus info: pci@0000:00:1f.2
             version: 31
             width: 32 bits
             clock: 33MHz (30.3ns)
             capabilities: bus_master
             resources: memory:9432c000-9432ffff
        *-multimedia
             description: Audio device
             product: Sunrise Point-H HD Audio
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 31
             width: 64 bits
             clock: 33MHz
             configuration: driver=snd_hda_intel latency=32
             resources: irq:133 memory:94328000-9432bfff memory:94310000-9431ffff
        *-serial UNCLAIMED
             description: SMBus
             product: Sunrise Point-H SMBus
             physical id: 1f.4
             bus info: pci@0000:00:1f.4
             version: 31
             width: 64 bits
             clock: 33MHz
             resources: memory:94335000-943350ff ioport:6040(size=32)
     *-scsi:0
          physical id: 2
          logical name: scsi0
          capabilities: emulated
        *-disk
             description: ATA Disk
             product: SAMSUNG MZNLF128
             physical id: 0.0.0
             bus info: scsi@0:0.0.0
             logical name: /dev/sda
             version: 1H1Q
             serial: S2HUNXAG836074
             capabilities: gpt-1.00 partitioned partitioned:gpt
             configuration: ansiversion=5 guid=8130209d-cb2b-4427-a2cb-5f1be6d0fd2c logicalsectorsize=512 sectorsize=512
           *-volume:0
                description: Windows FAT volume
                vendor: MSDOS5.0
                physical id: 1
                bus info: scsi@0:0.0.0,1
                logical name: /dev/sda1
                logical name: /boot/efi
                version: FAT32
                serial: 9e5f-9cd1
                capacity: 259MiB
                capabilities: boot precious readonly hidden nomount fat initialized
                configuration: FATs=2 filesystem=fat label=SYSTEM mount.fstype=vfat mount.options=rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro name=EFI system partition state=mounted
           *-volume:1
                description: reserved partition
                vendor: Windows
                physical id: 2
                bus info: scsi@0:0.0.0,2
                logical name: /dev/sda2
                serial: 31c5ba9e-05bb-4f66-810c-39eea4a14bb1
                capacity: 127MiB
                capabilities: nofs precious readonly hidden nomount
                configuration: name=Microsoft reserved partition
           *-volume:2
                description: Windows NTFS volume
                vendor: Windows
                physical id: 3
                bus info: scsi@0:0.0.0,3
                logical name: /dev/sda3
                version: 3.1
                serial: 30009556-0524-644e-a3dd-921bbc262c96
                capacity: 118GiB
                capabilities: ntfs initialized
                configuration: clustersize=4096 created=2015-08-29 08:34:46 filesystem=ntfs label=Windows name=Basic data partition state=clean
           *-volume:3
                vendor: Windows
                physical id: 4
                bus info: scsi@0:0.0.0,4
                logical name: /dev/sda4
                version: 3.1
                serial: a4f8-c088
                capacity: 862MiB
                capabilities: boot precious readonly hidden nomount ntfs initialized
                configuration: clustersize=4096 created=2016-01-10 03:42:47 filesystem=ntfs modified_by_chkdsk=true mounted_on_nt4=true resize_log_file=true state=dirty upgrade_on_mount=true
     *-scsi:1
          physical id: 3
          logical name: scsi2
        *-disk
             product: HGST HTS541010A9
             physical id: 0.0.0
             bus info: scsi@2:0.0.0
             logical name: /dev/sdb
             version: A710
             serial: JA1080SB0SVK2P
             configuration: ansiversion=5 guid=fd09d250-f1ab-463f-8b9d-90a9bcc9c61f logicalsectorsize=512 sectorsize=4096
           *-volume:0
                vendor: Windows
                physical id: 1
                bus info: scsi@2:0.0.0,1
                logical name: /dev/sdb1
                version: 3.1
                serial: 4efe49d7-60b5-c24b-979a-40bab471e293
                capacity: 279GiB
                configuration: clustersize=4096 created=2015-10-01 11:18:29 filesystem=ntfs label=DATA name=Basic data partition state=clean
           *-volume:1
                vendor: Windows
                physical id: 2
                bus info: scsi@2:0.0.0,2
                logical name: /dev/sdb2
                version: 3.1
                serial: cabde1a0-c9ea-9e44-b1ef-4f11e8bb9d28
                capacity: 16GiB
                configuration: clustersize=4096 created=2015-10-01 11:18:34 filesystem=ntfs label=RECOVERY modified_by_chkdsk=true mounted_on_nt4=true name=Basic data partition resize_log_file=true state=dirty upgrade_on_mount=true
           *-volume:2
                vendor: mkfs.fat
                physical id: 3
                bus info: scsi@2:0.0.0,3
                logical name: /dev/sdb3
                version: FAT32
                serial: c1d2-04f6
                capacity: 511MiB
                capabilities: boot fat initialized
                configuration: FATs=2 filesystem=fat name=EFI System Partition
           *-volume:3
                description: EXT4 volume
                vendor: Linux
                physical id: 4
                bus info: scsi@2:0.0.0,4
                logical name: /dev/sdb4
                logical name: /
                version: 1.0
                serial: 41c00ae8-a35f-499e-8eb4-6f57e27e621b
                capabilities: journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
                configuration: created=2016-05-03 11:23:25 filesystem=ext4 lastmountpoint=/ modified=2016-05-04 20:34:38 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,data=ordered mounted=2016-05-04 20:34:42 state=mounted
           *-volume:4
                description: Linux swap volume
                vendor: Linux
                physical id: 5
                bus info: scsi@2:0.0.0,5
                logical name: /dev/sdb5
                version: 1
                serial: 13ad6819-9463-464c-860a-704b4f929050
                capacity: 15GiB
                capabilities: nofs swap initialized
                configuration: filesystem=swap pagesize=4095
     *-scsi:2
          physical id: 4
          logical name: scsi3
        *-cdrom
             description: DVD-RAM writer
             product: DVDRW  SU208GB
             vendor: hp
             physical id: 0.0.0
             bus info: scsi@3:0.0.0
             logical name: /dev/cdrom
             logical name: /dev/cdrw
             logical name: /dev/dvd
             logical name: /dev/dvdrw
             logical name: /dev/sr0
             version: HH00
             capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
             configuration: ansiversion=5 status=nodisc
And here's my ridiculous experience with HP support:
08:45 Support session established with Pauline.
08:45 Pauline: Welcome to HP Chat Support. My name is Pauline and I will be your technical support specialist today.  Please allow me a few minutes while I review your information.
Meanwhile I request you to provide us with  your  Phone number and operating system so that we can update it in our records.
08:46 João Abrantes: phone number: +44 xxxxx
08:46 João Abrantes: OS: Windows and Ubuntu (dual boot)
08:48 Pauline: Thank you for your patience.
08:49 Pauline: Joao unfortunately at HP we do not support dual boot OS as we do not have much expertise over the same. However please contact Ubuntu so that they can help you further. If further support is required from HP you will need to reinstall the original operating system back on the PC and we will be able to help you further.
08:50 João Abrantes: I have the original OS installed
08:52 João Abrantes: Ubuntu is used by millions of users. If your hardware and customer service don't support such widely used Software you will lose all these clients..
08:52 Pauline: I am sorry however as I said we do not have much expertise over the same and hence kindly contact Ubuntu for the same.
08:54 João Abrantes: Ubutnu is not a company, they gave me their software for free. I paid you more than a thousand euros and all I get is incompatible hardware and no support.
08:54 João Abrantes: Is it possible to replace my laptop or my network adaptor? I still have warranty
08:55 Pauline: If the Pc is still under a month, you can approach the place of purchase to get it replaced.
08:55 João Abrantes: It's not under a month
08:55 João Abrantes: it's under 2 years which is my warranty period
08:56 Pauline: Joao unfortunately we cannot replace the PC if the time of purchase is more than a month.
08:56 João Abrantes: Not even my incompatible network adaptor?
08:57 Pauline: You will need to contact the place of purchase and check with their return and replacement policy.
08:58 João Abrantes: Ok this is useless. I am going to share this conversation in the Ubuntu forums. At least I can save time and money to other users by making them avoid buying HP incompatible hardware.
09:00 Pauline: I am sorry about the inconvenience caused, however please understand we do not have the expertise or required tools to help with another operating system issue.
09:00 João Abrantes: The network adaptor also causes problems on windows
09:00 João Abrantes: I can't start an hotspot
09:05 Pauline: Joao as I said if you will need to reinstall the original operating system on the Pc for us to troubleshoot. as in the original operating system, should be the only operating system on the PC.
09:06 João Abrantes: Windows is my original OS!
09:06 João Abrantes: and it is installed
09:07 Pauline: Joao I understand but currently there is a dual Os in the Pc and hence I will not be able to troubleshoot the same.
09:07 Pauline: Please run a recovery on the PC and get back to us with only the windows image loaded
09:07 Pauline: we will be able to help you with the same.
This solution was obtained from collaborative effort with the question poster.
Step 1. Disable secure boot from BIOS. (new modules will be added to the kernel)
Step 2. Add repository for the driver and install it.
sudo add-apt-repository ppa:hanipouspilot/rtlwifi sudo apt-get update sudo apt-get install rtlwifi-new-dkms linux-firmware
Your wifi-adapter should be working now (though maybe having weak signal).
Step 3. Edit the configuration file for the new driver for specific antenna selection and power management,
--First make a backup.
sudo cp /etc/modprobe.d/rtl8723be.conf /etc/modprobe.d/rtl8723be.old.conf
then,
echo "options rtl8723be fwlps=0 ips=0 ant_sel=2" | sudo tee /etc/modprobe.d/rtl8723be.conf
Step 4. reboot
Your wifi-adapter should be working better now. It is suggested to test wireless connection under load for some time. User may test with ant_sel=1 or removing this parameter to ascertain best working condition.
More information: With kernel update, no additional configuration is needed since linux-firmware is also installed.
Refering solutions : Another issue with rtl8723be
ankit7540
  • 4,195
