I can not remove broken package. Use the following command:
sudo apt-get -f install
but I get the following response:
Preparing to unpack .../nodejs_0.10.28-1chl1~trusty1_amd64.deb ...
Unpacking nodejs (0.10.28-1chl1~trusty1) over (0.10.25~dfsg2-2ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/nodejs_0.10.28-1chl1~trusty1_amd64.deb (--unpack):
trying to overwrite '/usr/share/man/man1/node.1.gz', which is also in package nodejs-legacy 0.10.25~dfsg2-2ubuntu1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Processing triggers for man-db (2.6.7.1-1) ...
I tried various commands like
2015 sudo apt-get clean
2020 sudo dpkg --configure -a
2023 sudo apt-get autoremove
2034 sudo apt-get upgrade && sudo apt-get -f install
But I did not get any result. I can not install synaptic. Any ideas how can I remove the broken package ?
