At Ubuntu Desktop 22.04 was executed:
sudo dpkg -i virtualbox-7.0_7.0.4-154605~Ubuntu~jammy_amd64.deb
but through the unpacking process was cancelled through ctrl + c. It because is need it the 6.1.40 version instead. Few seconds later was executed
sudo dpkg -i virtualbox-6.1_6.1.40-154048~Ubuntu~jammy_amd64.deb
and shows
(Reading database ... 200469 files and directories currently installed.)
Preparing to unpack virtualbox-6.1_6.1.40-154048~Ubuntu~jammy_amd64.deb ...
Unpacking virtualbox-6.1 (6.1.40-154048~Ubuntu~jammy) over (6.1.40-154048~Ubuntu~jammy) ...
dpkg: dependency problems prevent configuration of virtualbox-6.1:
 virtualbox-6.1 depends on libqt5core5a (>= 5.15.1); however:
  Package libqt5core5a is not installed.
 virtualbox-6.1 depends on libqt5gui5 (>= 5.14.1) | libqt5gui5-gles (>= 5.14.1); however:
  Package libqt5gui5 is not installed.
  Package libqt5gui5-gles is not installed.
 virtualbox-6.1 depends on libqt5opengl5 (>= 5.0.2); however:
  Package libqt5opengl5 is not installed.
 virtualbox-6.1 depends on libqt5printsupport5 (>= 5.0.2); however:
  Package libqt5printsupport5 is not installed.
 virtualbox-6.1 depends on libqt5widgets5 (>= 5.15.1); however:
  Package libqt5widgets5 is not installed.
 virtualbox-6.1 depends on libqt5x11extras5 (>= 5.6.0); however:
  Package libqt5x11extras5 is not installed.
 virtualbox-6.1 depends on libsdl1.2debian (>= 1.2.11); however:
  Package libsdl1.2debian is not installed.
dpkg: error processing package virtualbox-6.1 (--install): dependency problems - leaving unconfigured Processing triggers for mailcap (3.70+nmu1ubuntu1) ... Processing triggers for gnome-menus (3.36.0-1ubuntu3) ... Processing triggers for desktop-file-utils (0.26-1ubuntu3) ... Processing triggers for hicolor-icon-theme (0.17-2) ... Processing triggers for shared-mime-info (2.1-2) ... Errors were encountered while processing: virtualbox-6.1
Therefore was executed the sudo apt -f install and shows
Reading package lists... Done
Building dependency tree... Done
E: The package virtualbox-7.0 needs to be reinstalled, but I can't find an archive for it.
With sudo apt purge virtualbox-7.0 shows
If I try to re-install VB 7 to purge it later with
sudo apt install ./virtualbox-7.0_7.0.4-154605~Ubuntu~jammy_amd64.deb
It shows
You might want to run 'apt --fix-broken install' to correct these.
 virtualbox-6.1 : Depends: libqt5core5a (>= 5.15.1) but it is not installed
                  Depends: libqt5gui5 (>= 5.14.1) but it is not installed or
                           libqt5gui5-gles (>= 5.14.1) but it is not installed
                  Depends: libqt5opengl5 (>= 5.0.2) but it is not installed
                  Depends: libqt5printsupport5 (>= 5.0.2) but it is not installed
                  Depends: libqt5widgets5 (>= 5.15.1) but it is not installed
                  Depends: libqt5x11extras5 (>= 5.6.0) but it is not installed
                  Depends: libsdl1.2debian (>= 1.2.11)
                  Recommends: libsdl-ttf2.0-0 but it is not installed
                  Recommends: gcc but it is not installed
                  Recommends: make or
                              build-essential but it is not installed or
                              dpkg-dev but it is not installed
                  Recommends: binutils but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
If is executed apt --fix-broken install it shows
If I want to reinstall VB 6.1 with
sudo apt install ./virtualbox-6.1_6.1.40-154048~Ubuntu~jammy_amd64.deb
it shows (observe it stills refer to 7)
If I want to uninstall VB 6.1 with sudo apt purge virtualbox-6.1 it shows
How to fix this?
The goal is uninstall by complete VB 7 and install VB 6.1 in peace.
Alpha
According with the user535733's suggestion if is executed the command:
appears
dpkg: regarding virtualbox-7.0_7.0.4-154605~Ubuntu~jammy_amd64.deb containing virtualbox-7.0:
 virtualbox-7.0 conflicts with virtualbox
  virtualbox-6.1 provides virtualbox and is present and unpacked but not configured.
dpkg: error processing archive virtualbox-7.0_7.0.4-154605~Ubuntu~jammy_amd64.deb (--install): conflicting packages - not installing virtualbox-7.0 Errors were encountered while processing: virtualbox-7.0_7.0.4-154605~Ubuntu~jammy_amd64.deb
I find a possible solution about to use the command:
sudo dpkg --remove --force-remove-reinstreq <packagename>
it according with the post & solution:
But its first comment indicates:
This command should always be avoided as it breaks you system more than it repairs
Not sure if that is true or not. But is a risk
Solution
Therefore I did do the following and finally works:
sudo cp /var/lib/dpkg/status status.bkp
sudo gedit /var/lib/dpkg/status
Remove the section that contains the error message. In my case was:
Package: virtualbox-7.0
Status: install reinstreq half-installed
Priority: optional
Section: contrib/misc
Architecture: amd64
Version: 7.0.4-154605~Ubuntu~jammy
Observe the status - install reinstreq half-installed
The source/credits of this solution is thanks to this post
Therefore the commands work fine
sudo apt -f install
And about VirtualBox 7 with the following commands happens:
sudo apt remove virtualbox-7
E: Unable to locate package virtualbox-7
sudo apt remove virtualbox-7.0 Reading package lists... Done Building dependency tree... Done Reading state information... Done Package 'virtualbox-7.0' is not installed, so not removed 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
sudo apt purge virtualbox-7.0 Reading package lists... Done Building dependency tree... Done Reading state information... Done Package 'virtualbox-7.0' is not installed, so not removed 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
So it seems all is Ok.
