I have installed Ubuntu 16.04.2 LTS. I need to install the matlibplot python module. But whenever I try to install it with the command:
sudo apt-get install python-matplotlib
it shows the following errors:
 Reading package lists... Done
 Building dependency tree
 python-matplotlib : Depends: python-dateutil but it is not going to    be installed
                     Depends: python-numpy (>= 1:1.10.0~b1) but it is not going to be installed
                     Depends: python-numpy-abi9
                     Depends: python-cycler but it is not going to be installed
                     Depends: python:any (>= 2.7.5-5~)
                     Recommends: python-glade2 but it is not going to be installed
                     Recommends: python-imaging but it is not going to be installed
                     Recommends: python-tk (>= 2.5.2-1.1) but it is not going to be installed
How can I solve these problems?
Zanna
  • 72,312
MKS
  • 101
Cite:
Possible solution:
Run this command to remove broken packages in ubuntu.
sudo dpkg --remove --force-remove-reinstreq package_name
after removing package update your system with command
sudo apt-get update
Additional information:
«How to delete broken packages in ubuntu»
http://askubuntu.com/questions/525088/ddg#619956
