I wanted to give weechat a try on my Ubuntu 15.04 install so I downloaded a stable .deb from here (https://weechat.org/download/debian/) but I think I missed a few instructions because now everything is screwed up. Software Center keeps telling me "New software can't be installed, because there is a problem with the software currently installed. Do you want to repair this problem now?"
I tried sudo apt removing and purging weechat but I keep getting various of the following error message:
Reading package lists... Done Building dependency tree
Reading state information... Done Package 'weechat' is not installed,
so not removed You might want to run 'apt-get -f install' to correct
these: The following packages have unmet dependencies: weechat-curses
: Depends: weechat-core (= 1.1.1-1) but it is not going to be
installed E: Unmet dependencies. Try 'apt-get -f install' with no
packages (or specify a solution).
sudo apt-get -f install yields this error:
Unpacking weechat-core (1.1.1-1) ... dpkg: error processing archive
/var/cache/apt/archives/weechat-core_1.1.1-1_amd64.deb (--unpack):
trying to overwrite '/usr/share/locale/fr/LC_MESSAGES/weechat.mo',
which is also in package weechat-devel-core 1.4-1~dev20150904 dpkg-
deb: error: subprocess paste was killed by signal (Broken pipe) Errors
were encountered while processing: /var/cache/apt/archives/weechat-
core_1.1.1-1_amd64.deb E: Sub-process /usr/bin/dpkg returned an error
code (1)
I'm at my wits end. I tried install weechat core via apt to try to fix the dependency issue but nothing seems to be working. Any thoughts? I apologize for my ignorance - I've a newbie to Linux and Ubuntu and I'm mildly afraid I've borked my entire system!
Chris T
  • 133
Weechat is available through apt-get. Run the following commands:
sudo apt-get purge weechat* weechat-devel-core
If that doesn't work, run this instead:
sudo dpkg -P weechat-devel-core
Then,
sudo apt-get clean
sudo apt-get update
sudo apt-get install weechat*
In the future, you can search for pachages using apt-get by using the following example:
apt-cache search weechat | grep weechat
A.B.
  • 92,125
mchid
  • 44,904
  • 102
  • 162
