I am trying to clean up my /boot drive but I feel like I'm in a vicious circle. What I have tried so far is this:
$ df -h
/dev/xvda1                                   236M  230M     0 100% /boot
$ uname -r
3.19.0-64-generic
$ dpkg --list | grep linux-image
rc  linux-image-3.19.0-25-generic        3.19.0-25.26~14.04.1                amd64        Linux kernel image for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-3.19.0-49-generic        3.19.0-49.55~14.04.1                amd64        Linux kernel image for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-3.19.0-51-generic        3.19.0-51.58~14.04.1                amd64        Linux kernel image for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-3.19.0-56-generic        3.19.0-56.62~14.04.1                amd64        Linux kernel image for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-3.19.0-58-generic        3.19.0-58.64~14.04.1                amd64        Linux kernel image for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-3.19.0-59-generic        3.19.0-59.66~14.04.1                amd64        Linux kernel image for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-3.19.0-61-generic        3.19.0-61.69~14.04.1                amd64        Linux kernel image for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-3.19.0-64-generic        3.19.0-64.72~14.04.1                amd64        Linux kernel image for version 3.19.0 on 64 bit x86 SMP
rc  linux-image-extra-3.19.0-25-generic  3.19.0-25.26~14.04.1                amd64        Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-extra-3.19.0-49-generic  3.19.0-49.55~14.04.1                amd64        Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-extra-3.19.0-51-generic  3.19.0-51.58~14.04.1                amd64        Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-extra-3.19.0-56-generic  3.19.0-56.62~14.04.1                amd64        Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-extra-3.19.0-58-generic  3.19.0-58.64~14.04.1                amd64        Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-extra-3.19.0-59-generic  3.19.0-59.66~14.04.1                amd64        Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
ii  linux-image-extra-3.19.0-61-generic  3.19.0-61.69~14.04.1                amd64        Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
iF  linux-image-extra-3.19.0-64-generic  3.19.0-64.72~14.04.1                amd64        Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
rc  linux-image-extra-3.19.0-65-generic  3.19.0-65.73~14.04.1                amd64        Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
And when I try to remove one unused kernel I get the following error:
$ sudo apt-get remove linux-image-3.19.0-49-generic
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 linux-headers-generic-lts-vivid : Depends: linux-headers-3.19.0-73-generic but it is not going to be installed
 linux-image-extra-3.19.0-49-generic : Depends: linux-image-3.19.0-49-generic but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
When I try to install unmet dependencies, I get the following error.
apt-get -f install
unable to create `/usr/src/linux-headers-3.19.0-73-generic/include/config/ath9k/common.h.dpkg-new' (while processing `./usr/src/linux-headers-3.19.0-73-generic/include/config/ath9k/common.h'): No space left on device
No apport report written because the error message indicates a disk full error
        dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
 /var/cache/apt/archives/linux-headers-3.19.0-73-generic_3.19.0-73.81~14.04.1_amd64.deb
any suggestion what I can do about it? Can I manually/safely increase the size of /boot drive? Cheers
terdon
  • 104,119
According to the man page:
"autoremove is used to remove packages that were automatically installed to satisfy dependencies for other packages and are now no longer needed."
First try:
apt-get -s autoremove
This will do a simulated dry run of autoremove, which will tell you what it will remove for real when you run it without the -s option. If you are satsified it won't nuke anything you need, then:
apt-get autoremove
Note: it seems like your /boot partition is already completely full. You could run gparted from a live version CD (such as Knoppix) to redistribute your hard disk space and give /boot a bit more room.
dbkeys
  • 161
