How to solve this?
sudo apt install -f
Reading package lists... Done
Building dependency tree... Done
The following packages will be REMOVED:
linux-image-5.15.0-1063-raspi
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 11.5 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 129650 files and directories currently installed.)
Removing linux-image-5.15.0-1063-raspi (5.15.0-1063.66) ...
/etc/kernel/postrm.d/initramfs-tools:
update-initramfs: Deleting /boot/initrd.img-5.15.0-1063-raspi
/etc/kernel/postrm.d/zz-flash-kernel:
find: ‘/lib/firmware/5.15.0-1063-raspi’: No such file or directory
run-parts: /etc/kernel/postrm.d/zz-flash-kernel exited with return code 1
dpkg: error processing package linux-image-5.15.0-1063-raspi (--remove):
installed linux-image-5.15.0-1063-raspi package post-removal script subprocess returned error exit
status 1
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
needrestart is being skipped since dpkg has failed
I tried this:
sudo apt-get dist-upgrade
Calculating upgrade... Done
The following NEW packages will be installed:
linux-modules-5.15.0-1063-raspi
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 46.7 MB of archives.
After this operation, 199 MB of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 linux-modules-5.15.0-1063-raspi arm64 5.15.0-1063.66 [36.3 MB]
Get:2 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 linux-image-5.15.0-1063-raspi arm64 5.15.0-1063.66 [10.5 MB]
Fetched 46.7 MB in 10s (4714 kB/s)
Selecting previously unselected package linux-modules-5.15.0-1063-raspi.
Preparing to unpack .../linux-modules-5.15.0-1063-raspi_5.15.0-1063.66_arm64.deb ...
Unpacking linux-modules-5.15.0-1063-raspi (5.15.0-1063.66) ...
dpkg: dependency problems prevent configuration of linux-modules-5.15.0-1063-raspi:
linux-modules-5.15.0-1063-raspi depends on linux-image-5.15.0-1063-raspi; however:
Package linux-image-5.15.0-1063-raspi is not installed.
dpkg: error processing package linux-modules-5.15.0-1063-raspi (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
I tried
sudo dpkg --configure -a
whit no result.
Also tried
sudo apt autoremove
status 1
and
sudo apt clean
also tried
aptitude will not install due to problems
sudo apt install aptitude
The following additional packages will be installed:
aptitude-common bzip2 libboost-iostreams1.74.0 libcwidget4 libdpkg-perl libfile-fcntllock-perl
libsigc++-2.0-0v5 libxapian30
Suggested packages:
apt-xapian-index aptitude-doc-en | aptitude-doc debtags tasksel bzip2-doc libcwidget-dev
debian-keyring gcc | c-compiler bzr xapian-tools
aptitude aptitude-common bzip2 libboost-iostreams1.74.0 libcwidget4 libdpkg-perl
libfile-fcntllock-perl libsigc++-2.0-0v5 libxapian30
0 upgraded, 9 newly installed, 1 to remove and 2 not upgraded.
Need to get 4148 kB of archives.
After this operation, 10.0 MB of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 aptitude-common all 0.8.13-3ubuntu1 [1719 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports jammy/main arm64 libboost-iostreams1.74.0 arm64 1.74.0-14ubuntu3 [243 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports jammy/main arm64 libsigc++-2.0-0v5 arm64 2.10.4-2ubuntu3 [11.7 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 libcwidget4 arm64 0.5.18-5build1 [272 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 libxapian30 arm64 1.4.18-4 [656 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 aptitude arm64 0.8.13-3ubuntu1 [942 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports jammy/main arm64 bzip2 arm64 1.0.8-5build1 [34.6 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libdpkg-perl all 1.21.1ubuntu2.3 [237 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports jammy/main arm64 libfile-fcntllock-perl arm64 0.22-3build7 [33.7 kB]
Fetched 4148 kB in 1s (3057 kB/s)
(Reading database ... 129651 files and directories currently installed.)
status 1
