384
How can I increase the size of the root partition of a system at runtime?
I have a partition that is not allocated after the root partition (which is also ext4), how can I add that unallocated space to the space allocated to the root partition without having to shutdown the server?
Braiam
  • 69,112
BonboBingo
  • 3,942
10 Answers10
327
GUI (Ubuntu 14.04 and later): GParted v0.17 and later provide a nice GUI for this. (Older versions will refuse to resize a mounted partition).
Command line (any Ubuntu version): There are three steps to this.
Step 1. The partition must first be resized. If you're using LVM, it's easy, and you presumably know how to proceed. If you're using classic partitions, it's a bit more complicated, and may require a reboot (though you never have to boot another system or live CD).
This is how I do it: Use fdisk to first delete the partition (the idea is that the data on disk will be preserved), then carefully recreate it with a larger size at the same position.
Example:
$ sudo fdisk /dev/sda
Command (m for help): p
Device Boot Start End Blocks Id System /dev/sda1 * 2048 9437183 4717568 83 Linux
Command (m for help): d Selected partition 1
Command (m for help): n Command action e extended p primary partition (1-4) Select (default p): p Partition number (1-4, default 1): 1 First sector (2048-10485759, default 2048): Using default value 2048 Last sector, +sectors or +size{K,M,G} (2048-10485759, default 10485759): Using default value 10485759
Created a new partition 1 of type 'Linux' and of size 10 GiB. Partition #1 contains a ext4 signature.
Do you want to remove the signature? [Y]es/[N]o: N
Device Boot Start End Blocks Id System /dev/sda1 2048 10485759 5241856 83 Linux
Command (m for help): w The partition table has been altered!
Calling ioctl() to re-read partition table.
WARNING: Re-reading the partition table failed with error 16: Device or resource busy. The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8) Syncing disks.
Again, it is critical that the new partition starts at the same block as the old. The Id should also match (83 for Linux systems). Be prepared to lose all your data at the slightest typo.
To be on the safe side, you may also restore the boot flag (which according to Wikipedia is still required on some computers) by pressing a.
See the comment section for what to do if your swap partition is in the way.
By now it should be apparent why people recommend using a live CD. ;-)
Step 2. As fdisk helpfully reminds you, you must reload the partition table before proceeding. The safest way is to simply reboot; but you can also use partprobe or kpartx (more information).
Step 3. Once the partition is resized and the partition table reloaded, it's a simple matter of running resize2fs on the file system, and you can do this even when it's mounted as the root partition.
Example:
$ sudo resize2fs /dev/sda1
MewX
  • 105
215
An easier solution - use growpart <device> <partition>:
growpart /dev/xvda 1  # Grows the partition; note the space
resize2fs /dev/xvda1  # Grows the filesystem
As always, back up your partition table (sfdisk -d /dev/xvda > partition_bak.dmp) just in case.
growpart is part of cloud-utils. In case you don't have it, you can install with:
sudo apt-get install cloud-utils
Artur Meinild
  • 31,035
STRML
  • 2,261
138
It is possible to do a on-line resize of a ext4 filesystem, even if it's your root partition. Use the resize2fs command.
EDIT: On-line shrinking is not allowed:
root@brunojcm-htpc:/home# resize2fs /dev/sda5 2654693
resize2fs 1.42 (29-Nov-2011)
Filesystem at /dev/sda5 is mounted on /; on-line resizing required
resize2fs: On-line shrinking not supported
CodeAddict
  • 1,525
19
Yes, you can shrink/move/grow an online root partition without any reboots (nor livecd, nor usbkey): consult this answer. It's very well written and easy to follow, although quite long and a little risky. So if you only want to grow your ext4 partition, you can stick to the conventional working resize2fs solutions.
The general solution I've lnked will work on any type of dedicated or VPS solution for instance.
TLDR; this solution implies to pivot_root to tmpfs so you can umount safely your root partition live and fiddle with it. Once done, you'll pivot_root back on your new root partition.
This allows pretty much any manipulation on the root file system (move it, change filesystem, changing it's physical device...).
No reboot are required in the process, and this allows to bypass limitation of resize2fs not being able to shrink ext4 partitions.
I have personally used this, and it works very well on debian system also, so it should work on Ubuntu. I'm very surprised not to see this in-depth solution a little more linked to the many question in stackexchange web sites that deals with the same issue.
Note: Of course if you want to grow your partition, a simple resize2fs will be enough as stated in numerous places and in other answers here.
vaab
  • 1,112
14
You could also just make use of GParted - as long as the partition you are resizing is not the one you booted from - else I suggest the live CD option is somewhat easier for newbies.
GParted basically does all of the steps - just based on a GUI fronted.
11
I would like to make an extension on the answer of @Søren Løvborg: extending the partition with a swap partition present.
First the layout of the disk after extending it:
$sudo parted /dev/sda 'unit s print' free
Model: ATA VBOX HARDDISK (scsi)
Disk /dev/sda: 14336000s
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags 63s 2047s 1985s Free Space 1 2048s 10485759s 10483712s primary ext4 boot 10485760s 10487805s 2046s Free Space 2 10487806s 12580863s 2093058s extended 5 10487808s 12580863s 2093056s logical linux-swap(v1) 12580864s 14335999s 1755136s Free Space
So sda1 needs to be extended with the free space at the end of the disk, but the swap partition is in between them. This is how you can do it:
First we need to disable swap. Check how much it is used and if you can turn it off.
$ free -h
              total        used        free      shared  buff/cache   available
Mem:           992M         52M        464M        3.2M        475M        784M
Swap:          1.0G          0B        1.0G
swap is unused here so we can turn it off
$sudo swapoff /dev/sda5
Now we will change the partition table:
$sudo fdisk /dev/sda
(note: if you happen to have the first partition start at sector 63 instead of 2048, you need to add the option -c=dos)
Welcome to fdisk (util-linux 2.27.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help): p Disk /dev/sda: 6.9 GiB, 7340032000 bytes, 14336000 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x9e11c6df
Device Boot Start End Sectors Size Id Type /dev/sda1 * 2048 10485759 10483712 5G 83 Linux /dev/sda2 10487806 12580863 2093058 1022M 5 Extended /dev/sda5 10487808 12580863 2093056 1022M 82 Linux swap / Solaris
Command (m for help): d Partition number (1,2,5, default 5): 2
Partition 2 has been deleted.
Command (m for help): d Selected partition 1 Partition 1 has been deleted.
Command (m for help): n Partition type p primary (0 primary, 0 extended, 4 free) e extended (container for logical partitions) Select (default p): p Partition number (1-4, default 1): 1 First sector (2048-14335999, default 2048): Last sector, +sectors or +size{K,M,G,T,P} (2048-14335999, default 14335999): 12242941
Created a new partition 1 of type 'Linux' and of size 5.9 GiB.
Command (m for help): n Partition type p primary (1 primary, 0 extended, 3 free) e extended (container for logical partitions) Select (default p): p Partition number (2-4, default 2): 2 First sector (12242942-14335999, default 12242944): Last sector, +sectors or +size{K,M,G,T,P} (12242944-14335999, default 14335999):
Created a new partition 2 of type 'Linux' and of size 1022 MiB.
Command (m for help): a Partition number (1,2, default 2): 1
The bootable flag on partition 1 is enabled now.
Command (m for help): w The partition table has been altered. Calling ioctl() to re-read partition table. Re-reading the partition table failed.: Device or resource busy
The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8).
Note 1: the size of sda1 is the total amount of sectors minus the sector size of your swap partition: 14335999-2093058=12242941
Note 2: the command a is used to set the boot flag to a partition. Check the output of the first parted command. Usually this is the first partition.
As fdisk mentions: the kernel is still using the old partition table so we need to reload it.
$ sudo partprobe
Now we need to run resize2fs on sda1 (do not forget this!)
resize2fs 1.42.12 (29-Aug-2014)
Filesystem at /dev/sda1 is mounted on /; on-line resizing required
old_desc_blocks = 3, new_desc_blocks = 10
The filesystem on /dev/sda1 is now 38833617 (4k) blocks long.
Now, things are not over yet. As you've probably noticed sda2 is partitioned as type Linux (Ext4). For some reason, there is no way in fdisk to choose the type. So we have to alternate it using cfdisk
$ sudo cfdisk
Choose sda2 and change type to 82 Linux swap / Solarisand make sure you write it (type yes to confirm)
Now we can re-activate the swap
$ sudo mkswap /dev/sda2
/dev/sda2
UUID=d58bf1cb-d27a-487d-b337-056767fd5ad6 none swap sw 0 0
And finally turn it on:
$ swapon /dev/sda2
The only thing we need to do is to update fstab to mount the swap partition automatically upon booting
$ sudo nano /etc/fstab
And change the UUID of the swap partition to the output above:
# swap was on /dev/sda5 during installation
Now all is well and you can reboot without problems.
wouter205
  • 1,181
Just finished resizing an ext4 root partition on a live system while the root was mount.
[root@habib i686]# resize2fs /dev/vg_habib/lv_root
Filesystem at /dev/vg_habib/lv_root is mounted on /; on-line resizing required
old_desc_blocks = 4, new_desc_blocks = 10
Performing an on-line resize of /dev/vg_habib/lv_root to 38427648 (4k) blocks.
The filesystem on /dev/vg_habib/lv_root is now 38427648 blocks long.
[root@habib i686]#
CDR
  • 159
I just did this successfully without umount, pivot_root, or temporary removal of the main partition, using parted 3.2 on Ubuntu 16.04, 4.4.0 kernel. To be cautious I did everything from a virtual console with networking disabled, and took a snapshot beforehand just in case, but the snapshot wasn't needed, so I could have just as well done this via SSH and without changing runlevels.
Determine partition size: parted /dev/sda1 print | egrep "Disk.*GB"
Optionally switch to multi-user mode without networking (must be done from a console, not SSH):
runlevel     # remember the original runlevel
init 2
Optionally take a VM snapshot to be cautious.
Resize partition:
parted
p
resizepart NUMBER SIZE
# answer "Yes" when asked about resizing a live partition.
q
Resize filesystem: resize2fs /dev/sda1
If anything goes wrong, you could restore your snapshot here. If all went fine, return to normal runlevel (obtained above) - normally 5: init 5. It may be better to do a full reboot at this point to make sure everything comes back properly (I had a date/ntp issue afterward).
Follow these steps.
  1. open terminal as superuser su
  2. run parted
  3. type p to see the available partitions
  4. identify your root partition number (ex: 'sda 3' means number 3) and delete an adjacent partition by using rm PARTITION NUMBERto create free space.
  5. now increase the root size by typing resizepart ROOT NUMBER and reboot system if needed
  6. exit parted by typing exit and in terminal type partprobe and hit enter (this can be done even after rebooting)
  7. finally run resize2fs /dev/sda PARTITION NUMBER and enjoy spacious root partition.
-1
As stated before:
  • expanding live from a root system is possible.(no difficulties, as the boot section ain't to be moved)
  • shrinking a live root partition needs to be done from external boot device (boot from live system cd/usb-stick), as if there’s any fault, mismatch ..whatever..your system hangs, needs to be rebooted and will eventually not be able to boot correctly.
Any sort of "but I did it and it works" is pure luck.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
