First, here's what happened: I had OS X Mavericks (10.9) installed on my MacBook Pro. Then I wiped the operating system to get Windows 7 instead. After that, I went to install Ubuntu 12.04, but while installing, it wiped Windows 7 as well. Now I'm looking to reinstall Mac OS X, but I can't edit the partitions to create unallocated space, because it is stored in the ext4 partiton, mounted at "/". Any help would be appreciated.
edit: when I try to boot from any device (disk/USB/SD) this message shows up twice [error: efidisk read error.]
To create unallocated space, take your installation drive for Ubuntu, and click Try Ubuntu without installing from the GRUB Startup menu. Once logged in, look for GParted in the Ubuntu search menu. Once opened, select your Ubuntu partition, right-click it, then click "Resize" from the menu. Resize to the desired size, then install Maverick in the unallocated space.
Cheers
