I have installed Ubuntu 22.04 on a home server on 1 TB SSD with other drives of 6TB as storage. I needed some space on my SDD and noticed it is using less (approx ~ 500GB only). Looked at many suggestions and tried "resize2fs /dev/sda3" but it came up as "The filesystem is already 52428800 (4k) blocks long. Nothing to do!" I am lost at this point to understand what to do next to recover the missing ~500GB disk space and need your help!
My Aim: looking to recover the missing space so I can make use of it. Appreciate and thanks in advance for helping me here!
Here are the commands and outputs:
**root@rb:/# fdisk -l /dev/sda**
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: CT1000MX500SSD1
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 06080D25-52E6-43BE-8ABD-5DCE69016631
Device Start End Sectors Size Type
/dev/sda1 2048 4095 2048 1M BIOS boot
/dev/sda2 4096 2101247 2097152 1G Linux filesystem
/dev/sda3 2101248 421531647 419430400 200G Linux filesystem
/dev/sda4 421531648 631246847 209715200 100G Linux filesystem
/dev/sda5 631246848 652218367 20971520 10G Linux filesystem
/dev/sda6 652218368 861933567 209715200 100G Linux filesystem
root@rb:/# lsblk /dev/sda
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 1M 0 part
├─sda2 8:2 0 1G 0 part /boot
├─sda3 8:3 0 200G 0 part /
├─sda4 8:4 0 100G 0 part /var
├─sda5 8:5 0 10G 0 part /usr
└─sda6 8:6 0 100G 0 part /home
root@rb:/# df -h | grep -v overlay
Filesystem Size Used Avail Use% Mounted on
tmpfs 3.2G 6.5M 3.2G 1% /run
/dev/sda3 196G 8.4G 178G 5% /
/dev/sda5 9.8G 5.1G 4.2G 55% /usr
tmpfs 16G 0 16G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 16G 0 16G 0% /run/shm
/dev/sda4 98G 5.5G 88G 6% /var
/dev/sda2 974M 336M 571M 38% /boot
/dev/sda6 98G 24M 93G 1% /home
/dev/sdb5 4.0T 3.3T 428G 89% /export
/dev/sdb1 92G 8.0K 87G 1% /export/mnt/root
/dev/sdc 916G 72K 870G 1% /export/mnt/1tb
/dev/sdb4 1.4T 8.0K 1.3T 1% /export/mnt/home
tmpfs 3.2G 4.0K 3.2G 1% /run/user/1000
