I need to resize root as there is not enough space left in the partition. At present I am not able to install new package nor update ubuntu. I tried sudo apt-get clean and emptying trash but it does not make significant space.
I have dual boot system (windows-7 and Ubuntu 14.04 LTS) with two Internal hard drive. Where Windows is installed in /dev/sda and Ubuntu is installed in /dev/sdb. I tried to resize root using Gparted but it does not allow. Please let me know the steps of using Gparted for resizing root. I want to transfer space from "/home" to "/".
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sdb5 14G 13G 271M 98% /
none 4.0K 0 4.0K 0% /sys/fs/cgroup
udev 3.8G 8.0K 3.8G 1% /dev
tmpfs 779M 1.3M 777M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 3.8G 160K 3.8G 1% /run/shm
none 100M 56K 100M 1% /run/user
/dev/sdb1 3.7G 555M 2.9G 16% /boot
/dev/sdb7 896G 75G 776G 9% /home
sudo fdisk -l
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x38696756
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 206848 976771071 488282112 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Disk identifier: 0x000a1848
/dev/sdb1 * 2048 7852031 3924992 83 Linux
/dev/sdb2 7854078 1953523711 972834817 5 Extended
Partition 2 does not start on physical sector boundary.
/dev/sdb5 7854080 37148671 14647296 83 Linux
/dev/sdb6 37150720 45043711 3946496 82 Linux swap / Solaris
/dev/sdb7 45045760 1953523711 954238976 83 Linux
Thank you
