After installing Ubuntu server how do I install the desktop environment?
Depending on which desktop you wish to install, you install the the meta-package that installs all the necessary packages. You can use apt-get or aptitude to do this.
sudo apt install ubuntu-desktop
installs the Unity desktop
sudo apt install kubuntu-desktop
would install the KDE desktop
Other desktop meta-packages are xubuntu-desktop, ubuntu-gnome-desktop, lubuntu-desktop, and edubuntu-desktop.
Note: as default, apt install will also install all the recommended packages. Having recommended packages is usually desired for desktop users, but it may be undesired on a server since it's a lot of additional stuff.
- 317
- 29,406
From Ubuntu 20.04, we could use sudo apt install ubuntu-desktop-minimal to minimal install ubuntu-desktop, it removes around 80 packages (and related cruft) from the default install, including Thunderbird, LibreOffice and so on.
The command could replace the old command sudo apt-get install --no-install-recommends ubuntu-desktop or sudo aptitude install --without-recommends ubuntu-desktop.
- 411
If you just need to run virtual GUI (GUI exsists but you dont need to see it) on the computer for testing or other purposes.
sudo apt-get install xvnc4viewer
Is a setup I have.
- 35,659
