I just reset my username and password and am logging in for the first time since reset. After entering username and password, I get a prompt
username@ubuntu:~$
What do I type in for that?
username@ubuntu:~$
The prompt ~$ means you are currently in your home directory (indicated by ~) and you are a normal user (not super user) indicated by $.
For a normal user:
username@ubuntu:~$ pwd
/home/username
username@ubuntu:~$ whoami
username
For root (check #):
root@ubuntu:~# pwd
/root
root@ubuntu:~# whoami
root
To getting started to using the terminal read this documentation properly.
Is this prompt a terminal/shell screen? If so, it denotes you are at your home directory. The ~ is shorthand for /home/$USER/ dir and the $ denotes the line of the console in which your user is typing.
If you are confused by the terminal prompt, and are expecting a GUI Desktop, you may not have one installed or loaded (such as "Unity" or "GNome").
Try searching the web for various desktop environments for Ubuntu. The great thing about Linux/Ubuntu is options! Here is a default means of installing a desktop:
sudo apt-get install ubuntu-desktop
Check out this answer as well: How to install GUI desktop on a server?. I would encourage you to check out some other options first, then decide which you think you will like best.
You can spot check internet connectivity with:
ping www.google.com
or:
curl www.google.com
(if you dont have curl installed by default, see below)
From the command line, you can install most programs with the following command:
apt-get install <package-name>
For help, try man apt-get
