I am in the middle of installing Ubuntu server, but, I will not lie, I have no clue how to use it. Can I use it as a desktop or any help or how to start using? what are my expectations? Will I end up seeing a terminal only? Any advice? enter image description here
Ubuntu Server is not intended for home use, only for server use.
However, if you want to make it suitable for home usage, you may in the installation when it gets to the "Select Desktop" (or something like that) part, select the normal desktop, or KDE, LXDE, Cinnamon, etc.
If you choose no desktop at that part, then when the installation is done, you can install any desktop environment. Here's 3 codes to install Unity, KDE and LXDE (and only install one of these):
Unity:
sudo apt-get install ubuntu-desktop
KDE:
sudo apt-get install kubuntu-desktop
LXDE:
sudo apt-get install lubuntu-desktop
If you want more than 2 desktops, you'll need to get GDM.
sudo apt-get install gdm
You should be good now.
Star OS
  • 2,668
On load you will see a terminal line If you run apt-get install ubuntu-desktop you will end up with the functional equivalent of Desktop Edition. While also having all that the server package has
