When we do manual disk configuration for installation with 24.04 LTS, there is no option to encrypt partion (not disk). There is one option to erase whole disk rather than partition and it also requires to disable windows bitlocker. There are many posts that are in this context but none answers about future support. I currently have 22.04 LTS and it has root encrypted and I want to continue on same line. If we upgrade to 24.04 from previous installation, then it will still have encrypted partition. So, it does not make sense option for encryption for partition is not supported. Here is the question - if partition encryption with dual boot is not supported, then will it be added in future or shortly or it is a missing feature like bug that will be addressed soon?
Asked
Active
Viewed 4,623 times
You could solve this problem by installing Ubuntu Unity 24.04 instead of the default flavor of Ubuntu 24.04. In particular, when doing manual disk configuration, you would need to recreate the partition that is intended to be encrypted (it won't work if you just reformat an existing partition), and select ex4 or other partition formats, and then select encrypt.
Note that if your /boot is not in an encrypted partition, the installer might show a warning. However, grub might not work if /boot was in an encrypted partition, so you should probably just ignore the warning.
Once installation is done, you could run sudo apt install ubuntu-desktop to install the desktop environment of the default flavor.
References:
Shaform
- 1
